Results 1 to 20 of 20
    SF Bay Area
    Default Mini compressor and flat repair kit?
    Hello and suggestions welcomed.....
    I'm in the preliminary stage of planning a trip with my two wheeled friends to Death Valley. Since a lot of this trip will be in the middle of no-where, thought it would be a good idea to carry some kind of mini compressor and some kind of flat repair kit. Any suggestions? I used to carry some kind of 'plug' repair kit on my two wheeler but wasn't real happy with it.
    Thanks in advance!
    Feb 2009
    Canby, OR
    The best compressor is the one Harley sells - inexpensive, high quality, in its own pouch and has multiple power options, including using the dongle for my Battery Tender.
    For tire repair, Motorcycle Consumer News reviewed a nice easy to use Dynaplug kit, that I was so impressed with, I bought one for my (adult) kids and myself for Christmas - best of all, it fits in the compressor bag...
    All of this at under 2# and roughly 3x4x5 inches.. and about $60 for everything you need.
    Sep 2014
    3rd ROCK FROM THE SUN !
    check to see if the compressor you get will operate on the amp (fuse) capacity of your bike.. I bought the "STOP & GO" compressor from www.motorcyclesuperstore.com... it works on my Spyder.. it comes with in a case and its pretty small...
    osm
    Feb 2014
    Utica, Michigan
    Default Agree with OSM
    Quote Originally Posted by Orange Spyder Man View Post
    osm
    I kept blowing fuses with the $6 yellow crappy Harbor Freight compressor but now that I have it on a 15 amp fused line, no problems at all.
    Oct 2011
    Jacksonville,Ar
    I use the one by slim. It works great.
    15 rt , yes Black
    Aug 2010
    Riverside, California
    Nov 2012
    North Las Vegas, NV
    I have a Bell compressor and a tire plug kit with valve cores patches plugs and tools.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    South Okanagan, BC, Canada
    I also carry a small compressor and plug repair tools and plugs. As others have said, make sure it is compatible so as not to blow fuses. I have to admit that I've never had to use the plug repair stuff so not sure how well it will work but at least it's something.
    Another option is to put Ride On tire sealant in your tires before going. If you are not familiar with it do a google search. It is NOT like other slime type products that make a bad mess when removing the tire and many motorcyclists swear by it. I'm probably going to put some in my rear tire when I replace it shortly.
    Gary
    You can also find a very compact compressor and patch kit in the Dennis Kirk catalogs.
    Default A Little Research
    The pigtail for my Battery Tender Junior has a 7.5 amp inline fuse as does the Harley compressor pigtail which makes the latter the choice as there's no need for a second pigtail hooked to the battery. Although Battery Tender told me they did not recommend connecting any other accessory to the pigtail, that was before I found out the size of the fuse in the Harley compressor system.
    Harper, Texas
    I have used ride on for years. Works well, will not corrode your wheels. It has saved me from having tires go flat several times.
    Jun 2010
    Las Vegas
    Quote Originally Posted by Dragonrider View Post
    I tried others and also found that the Harley compressor is best.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    http://www.ride-on.com/ this stuff is the best watch the video
    Apr 2011
    GREENVILLE, SC
    Default COMPRESSOR
    under my false-floor, i carry a mini-compressor, tire plug kit, 1 qt of oil, rag & a locking cable.
    i wouldn't ride down the street without this stuff...
    dp
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    look at the latest edition of motorcycle road runner mag there is a write up about mini compressors
    Active Member Slagiatt's Avatar
    Jan 2013
    NW Indianapolis
    Default Ride-on...and ride on.
    Just piling on here to recommend Ride-On.
    I've used it in all tires in both of my Spyders. Worth every penny. (It also actually helps balance your wheels.)
    There are many compressors on the market...I have the brand name, "Slime". Works great...its digital readout is very convenient.
    As mentioned earlier, I won't ride around the block without my compressor...doesn't take that much room (about the size of a typical book.)
    F3S Steel Black Metallic
    Former owner of '12 RT-S SE-5 and '09 GS SM5
    Oct 2010
    Cincinnati Ohio
    I have this one. Works well for its size. Was 19.99 when I bought it it showed 39.99 when I ordered it.
    http://www.cyclegear.com/DOUBLE-TOUG...Air-Compressor
    Dec 2014
    Lee's Summit, MO
    Quote Originally Posted by SPYD3R View Post
    dp
    Something about being prepared.
    Jun 2014
    Washington State
    Default compressor/repair kit
    The Feb. 2015 issue of Road Runner Motorcycle Touring & Travel magazine reviewed 6 different compressors ranging in price from $100 (Best Rest) to $37 (Stop N Go) and the reviewers opinion was that he would be comfortable with any of those that were reviewed. I have the Stop N Go and it's the best insurance policy I have ever bought. For me, the space (or lack of) was the biggest factor since my two-wheel machines do not have the storage capacity of my RT-S.
    For plugging, I carry the Stop N Go Pocket Repair kit with the "mushroom headed" plugs.
    Fortunately, I've never needed to use either for a road emergency.
    Sep 2014
    East Texas
    dp
    Very well thought out. Worthy of emulating. Thanks.
