Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
  1. #26
    Jun 2013
    Quote Originally Posted by jaherbst View Post
    Down here in Tucson we just ride em year around!
    Bring em down to az for a winter vacation. They will love you forever and promise never to break down again.
    Jack
    I'm riding to Tucson and back in April . . . looking forward to seeing Arizona, again . . . been a long time.
  2. #27
    Aug 2013
    Quote Originally Posted by cuznjohn View Post
    just remember the flat spot will only on the bottom, so just ride on the tops
    Oh yeah, oops...
  3. #28
    Oct 2014
    Deep South
    My last Goldwing used to develop a flat spot over the winter when I forgot to put it on the center stand. It normally took me a good 2500 feet of riding before the tire flexed and warmed up enough to make it go away until the next spring.
  4. #29
    Mar 2012
    NJ
  5. #30
    Jun 2014
    People's Republic of NY
    You also might want to plug the exhaust pipes. Critters just love those cozy pipes.
    question for you is that your puppy?
  6. #31
    May 2013
    Redlands, Ca
    Quote Originally Posted by vided View Post
    I learned the hard way to not stuff those pipes with left over July 4th Roman candles. Especially if you have a less-than-perfect memory.
  7. #32
    PLEEZE tell us that you've got a video!
  8. #33
    Jun 2012
    Fairmont, Minnesota
    To help with flat spotting, increase the tire air pressure to about 30 lbs in front and 40 lbs in the rear. It helps but, don't ride it with those pressures as the handling will be atrocious.
  9. #34
    Those are just about the same pressures that I set mine at...
    ...with a note on the dash!
  10. #35
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    What's winterizing?
  11. #36
    Mine will be similar to some and different from some.
    Gas Stabilizer in the tank, hooked up to a battery tender. Mine are parked on a concrete floor (radiant heated garage floor).
    I don't worry about tire pressure or starting the bike at intervals. Tire pressure gets fixed when I prepare to do that first spring ride.
    I don't do the start up thing because I don't want to leave the running long enough to get it up to operating temperature.
    I'll start mine a couple of times; each winter...
    I just love to hear and feel it rev!
    Back it out of the garage into the driveway; and let my mind wander...
  13. #38
    Sep 2014
    Madison AL
    Quote Originally Posted by scott16119 View Post
    I wouldn't worry about the tires being on concrete. I know many disagree with starting an engine periodically. I've done it all my life with motorcycles , snowmobiles, cars, lawnmowers, snow blowers, about anything that has an engine.. I don't go starting it when it's -20 or anything, but if it's a nice winter day and I'm in the mood I will run it for a few minutes. If it's nice enough I'll ride the Spyder a mile or two. Does it do it any good? Probably not. But I disagree that's it's going to damage anything.
    I ride my RT when it's not too cold here in northern AL, and I keep it on the tender. I don't have to ride it 30 miles for it to reach operating temperature. As long as it's not freezing and ice is on the roads I ride it. I noticed letting it sit more than 2 weeks makes for hard starting.
  14. #39
    Mar 2013
    Glasgow, KY
    Default Gas Stabilizer
    Is there a recommended brand of gas stabilizer or is STA-BIL it?
    Mike in KY
  15. #40
    Mar 2013
    Quote Originally Posted by metman View Post
    Mike in KY
    I have always used STA-BIL, but a lot of people use SeaFoam with success.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  16. #41
    Mar 2012
    NJ
  17. #42
    I've used the Red stuff for years; but the Marine version deals with ethanol better...
  18. #43
    Mar 2013
    Glasgow, KY
    Thanks guys. I am gonna have to buy something, as the RED I currently have is over two years old and the bottle says it's only good for two years once opened.
    I'll look for the Marine STA-BIL as we have lots of boat places around here.
    Mike in KY
  19. #44
    Mar 2012
    NJ
  20. #45
    GreatFalls Montana
    Default Tires & cold concrete
    As said many times before, if you can't ride it don't start it.
    Rode Lightnin' LeeRoy to work again yesterday.
Tags for this Thread
