Results 1 to 25 of 31
    Active Member AppleSpyder's Avatar
    Tombstone, AZ
    Default Don't you hate it when.......
    1. you can't open your seat and realize you're turning the key the wrong way?
    2. your Spyder won't start because you don't have your foot on the brake?
    3. your Spyder wont go into gear because you don't have your foot on the break?
    4. you forget to put the parking break on and turn off your bike in a crowded area? beep beep beep
    5. your friends are all set to ride and you have to wait for the systems check to finish?
    6. you're set to make the great escape but your Spyder won't go because you forgot to take off the parking break?
    7. you're being cool by reversing out of a tight spot and then have to sit and wait for it to shift back into first gear?
    8. you want to up shift but down shift instead? YIKES!
    2016 F3-L Special Series Triple Black
    August 25, 2016
    2014 ST-Limited
    July 2, 2014
    "Just going down that long lonesome highway" and now REALLY loving every minute!!
    Active Member Dgjason's Avatar
    Old River Winfree Texas
    LOL Soooo true....
    Default No..!!
    get a manual..!! but I do see it a lot when we are on group rydes. The old pros have it worked out but it takes time to get the sequence righ and smooth. The only one I don't see is anyone pulling down the safety card.....
    Sep 2012
    Junction City, KS, USA
    All those things have happened to me. I've got the shut down pretty much 2nd nature now, though.
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    I do that every time. I didn't think the bike would start if you don't do that before you push the mode button.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Tombstone, AZ
    Default Safety Card
    Good one!!!! Should have put that one in the line up!!!!!!
    August 25, 2016
    2014 ST-Limited
    July 2, 2014
    Gloucester, VA
    Been there done every one of them. my 2014 also beeps if you try to take off in gear with the emergency brake on.
    Invalid Emails
    Apr 2014
    Northwood NH
    Add in "Your Spyder won't start because the shutoff switch is in the off position"
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by AppleSpyder View Post
    Is that a change for 2014s???? No need to have foot on brake to put in gear on my 09 or 13.
    Warwick, RI
    How about when you stuff the trunk so full that, when it clicks, you get this feeling that you will never get it open again. It will become a time capsule.
    Very Active Member Don in E Texas's Avatar
    Feb 2009
    Gilmer, TX
    Default No need to depress brake peddle....
    ...if you place the transmission in neutral prior to shutting engine off. I place engine in neutral, engage parking brake, open frunk - turn engine off. Get off bike and place helmet in frunk. When I go to ride again, I turn key to open frunk, turn key to "on" position and while bike does its 'thing' I get helmet/gloves etc. on. Hit the Mode button then the start button. I'm ready to get on the bike and ride. Can start bike from either side. Works on all Semi Auto equiped bikes as far as I know. Worked on my '08 and works on my '10.
    Don
    Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
    Now Own: 2014 Black RT-S SE6
    Welcome to the been there, done that, and have the T-shirt club.
    I guess that's why we love the so much.
    Invalid Emails
    Apr 2014
    Northwood NH
    I guess stupidity loves company. They're foolish mistakes that we all make
    Do you mean that these things don't happen to everybody; ALL of the time?
    NOTE TO SELF: Read the dang manual again!
    Apr 2011
    GREENVILLE, SC
    Default bin dere
    bin dere, dun dat.....
    it hit'n it into a lower gear, when you mean for a higher gear, now that is upsetting.... VAROOOOOOOOMMMMM..... goes the RPM's....
    Jul 2013
    Katy, TX
    Default Humm
    I thought that's what makes them so fun to ride. I smile just cause I got it started.
    How many times have you tried to upshift, with the horn button?
    Jun 2013
    But . . . but . . . you mean we don't have to read the entire safety card, every time!
    Oct 2013
    rome new york
    Put a picture of the F3 on my pull down card. The white one
    Clermont, Florida
    Even after years of Spyder ryding, those things still crop up occasionally
    Jul 2011
    Edmonton, Alberta
    Only 1,5 and 6 on my SM, but even that annoyance can still raise a grin.
    Tombstone, AZ
    Bwaaaa hahahaha!!!! Scares the pants right off of ya!!!! And then you say "ooopppss"
    August 25, 2016
    2014 ST-Limited
    July 2, 2014
    GOS member (Girls On Spyders) ruthie's Avatar
    Feb 2011
    Collinsville, Mississippi
    To solve #5 I turn the key on just before I get ready to put on my helmet, so by the time I get helmet on and get on the bike is ready to start.
    2014 RT SE6 Limited
    rYding Safe = Having Fun
    Ruthie
    Mar 2013
    1) check
    2) check
    3) check
    4) check
    5) check
    6) check
    7) check
    8) check
    Yep done them all
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member cyclelover63's Avatar
    Mar 2011
    Big Sandy, TN
    I hate it when I hit the kill switch at 70 mph by accident!
