Results 1 to 23 of 23
    Dec 2010
    benson,mn.
    Default 2014 RT with a NOISE/WHINE from engine - any ideas/fixes?
    on a 2014 rt, what is this rattle - whine - gear type of noise coming from the engine? It is really loud when slower driving in town, It is very loud and annoying. Thanks
    Oct 2011
    Niagara Region Ontario Canada
    Default noise
    I don't know what it is but I am looking forward to the replies you'll get....... Mine has the whine also. I look around when going down the road if anyone turns to see what noisy contraption is coming behind them ( they do) Worse than my mother in laws whine in older days...(very annoying..haha)
    I am thinking its just the jet beginning to wind out. I am used to it and kind of like it. I also liked the Mazda Wankel Rotary engine pickup truck sound from the 70's--so may be a bit biased.
    Is this a new development, or has your bike always made the noise?
    Active Member Tony8472's Avatar
    Gilbert, AZ
    Default 36 mph
    I have a whine in my 2014 RT but it is only at exactly 36 mph. Not at 35 - not at 37. Just 36. So I just ignore it and don't travel at 36 mph.
    Tony
    2014 RT
    Mods: Adjustable side wind deflectors; Adjustable vented windshield; Rear and front trunk lights; Replaced the foot pegs with Web Boards; Gerbing heater controls; Garmin Zumo 390LM GPS; Fog lights; Front headlamp accent lights; Replaced the standard fender light bulbs with LEDs; BumpSkid; Frunk insert and stripes from WrapMySPyder; BajaRon Swaybar; Laser alignment.
    Apr 2012
    Northglenn Colorado
    When I test drove the 2014 RT at the owners event in Durango CO thought the bike made a lot of noise with the fans and what not. It was sort of annoying but i figured something under there has to make this beast go!!!!
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default Yes...some noise here as well...just living with it
    Yes, I have a whine in the transmission (my guess) when I'm in 5th gear....it's typically when going through a town or cornering, etc. I think it's about the same now as when the bike had about 1500 miles on it -- I now have 11,000 miles on it. I'm just living with it and have not notified the dealer/tech about it. I shift gears to minimize the noise at this point.
    The 2014 RT is AWESOME and absolutely no oil usage....as long as it continues to run well, I think I can manage this "whine"!
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Feb 2009
    Canby, OR
    The loud whine is probably your fuel pump. There have been a fair number of folks with this issue, but I have yet to hear of one failing. Get it replaced with a new one, and the noise goes away (or so I'm told).
    I'll have mine changed in the Spring, when I go in for my 3K service.
    Fuel pumps have been making the rounds in here...
    But you've described a rattle, and they don't do that!
    (Unless they fall of the bike, and are rolling across the pavement! )
    Mar 2013
    Quote Originally Posted by eagle View Post
    Try this - at idle put pressure on the end of your handle bar as if to turn. It dosen't matter left or right. By doing so does the noise get louder? If it does it may be your alternator.
    Mine was replaced last month due to this.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Good catch!!
    Oct 2011
    Default Noise
    As stated, mine is noisy and has been since delivery. I've got 10,500 clicks on it now and it seems a little less noisy. Maybe I'm just getting used to it or my hearing aid battery needs replacing. Ride Safe and have a good one.
    Default Depends..!
    these are tight engines. There is some whirring and whinning but vary with rpms. If you have a constant sound will probably be the fuel pump. You walk around the spyder and see if you can localize the area it is coming from...
    Active Member HIspyder's Avatar
    Sep 2014
    Kauai (The Garden Isle), Hawaii - USA
    I'm trying to find an exploded view of the 1330 ACE but just by looking at the beginning of this video I can clearly see the timing chain lower gear is being driven via straight cut spur gears at the crankshaft. Straight cut gears are notorious for producing the type of whining noise you describe and is perfectly normal.
    Have you ever heard a V-8 engine with an aftermarket gear drive cam installed? Very noisy.
    Just another crappy day in Paradise....Aloha!
    Linden, CA
    If you look close your Spyder RT with the new 3 cyl. engine has a
    control for removing and or deminishing the noise, it's right
    there it's marked volume control, just turn it up works every time
    Active Member Farmbanker's Avatar
    Sep 2012
    Alburnett, Iowa
    My 2012 rt has a bit of a rattle/whine when cornering at low speed. Always has since new and I have 12k miles on it now. Thought maybe the clutch....
    Red 2016 RTS, Diamond R Armrests, Ram X Mount, Doc Humphreys Dampener, BajaRon Swaybar, Spyderpops "Critter Splitter"
    "It is the common fate of the indolent to see their rights become a prey to the active. The condition upon which God hath given liberty to man is eternal vigilance; which condition if he break, servitude is at once the consequence of his crime and the punishment of his guilt." John Philpot Curran 1790
    Wheel bearing??
    Jax Beach, Fl.
    Yes, I have the same constant whine from my 2014 engine compartment. I only notice the whinning noise at idle. But this engine is so smooth and emits very little noise otherwise. When compared to my 2012 V-twin engine. Which was a lot louder, I had to turn the volume way up just to hear the radio. I love the ACE 1330 engine
    Jun 2014
    Green Bay, Wi.
    Default Noise
    My 2014 RT-S SE 6 was noisy under 45 MPH until about 2000 miles, then it quieted down, like it was a different bike. The noise was worse when the engine temp was up to normal. MarcusB
    United States
    A 3' plastic PVC pipe works pretty good walking around and listening through it while it idles.
    Northern Kalifornia
    Default 1330 whine
    Get a tailgunner exhaust and you won't hear any more whine. In fact, you won't hear anything for 2 hours after you shut your off.
    Mar 2013
    WHAT?
    Dec 2012
    Greece
    Some of the sound is from the fuel system all ok.. So just ride and have fun. They all have that sound.
