Results 1 to 15 of 15
    Active Member TOPDOGJIM's Avatar
    Jul 2011
    South Windsor CT
    Default stranded in Gettysburg PA
    Put on 400 miles since the clutch master cyclender was filled and bleed. Now it is doing the same thing. The fluid is gone, the clutch won't engage. Where is the brake fluid going? I see there is a dealer in Hanover. Any ideas? On top of everything else I have been sick in bed for most of the day. I'm 350 miles from home. Missed every ride on the rally.
    "THE DOG SLED"
    2011 Spyder Can Am RTS SM5 (Orbital Blue)
    Nuvi 550 GPS With Ram Mount
    Drink 2 Go Cup Holder
    KewlMetal RT Run-Turn-Brake LED
    GloRyder Wolf Paw (in blue)
    DMWMS Decal
    IPS w/
    Alaska Leather Sheepskin Butt Pad
    TricLed - Brake Pedal
    Chrome Shortee Antenna
    SpyderLovers Sponsor
    Mar 2014
    Myerstown, Pa
    I know nothing about the Hanover dealer but I do know that the dealer in Ephrata has a very good certified mechanic. That's where my bike goes and has always been fixed properly the first time.
    Good people (Andy is service manager).
    Very reasonable prices also, at least that has been my experience.
    They are not to far from you either.
    Nov 2013
    Lutz, fl
    Hi, if you have or can download Roger's app
    "Spyder codes" he has a list of all dealers in the state. Good luck.
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Default Mortorsports in Hanover PA
    http://www.motosportsinc.com/
    Motosports Inc.
    2117 Baltimore Pike Hanover PA 17331
    Phone: 717-632-7093 Fax: 717-632-1404
    I am told they provide good service, a number of folks from Baltimore go past the local dealer to get serviced up there.
    Charles
    Sep 2014
    Columbia, Maryland
    Quote Originally Posted by WA5VHU View Post
    Motosports Inc.
    Charles
    Had both my Spyders serviced there a few weeks ago. I was very satisfied.
    - Rich
    2013 ST , Gray
    Default Let's see..!!
    I would recommend rebuilding the master and slave cylinders. In some cases where there is a loss of fluid and it is black and sludgy refilling and bleeding is not enough. If none is leaking to the ground it may be leaking into the crankcase....good luck..!!
    Clermont, Florida
    Sorry to hear of your troubles Good luck to you
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Hanover Motosports provides great service. I purchased my 2014 from them and I traveled a little over 100 miles to get it serviced there bypassing 4 dealers that are closer.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Default clutch
    My bike is in shop for the same thing it is the O rings , piston in the clutch ass. Look up 2013 -5 service bulletin in the forum it was posted 2 weeks ago. You can fill it again with DOT 4 and make it home because they will not have the parts to fix it parts on order. Picking up my bike today. Good luck
    Sep 2014
    mathias,wv
    PM sent
    Jul 2011
    South Windsor CT
    Bingo, problem solved.
    "THE DOG SLED"
    DMWMS Decal
    IPS w/
    Jun 2013
    The dealer in Hanover, PA is exceptional . . . They will take great care of you.
    Jul 2011
    South Windsor CT
    Thumbs up
    Motosports Inc.
    Charles
    Just an incredible good experience with Motosports! Without notice I had my Spyder towed there only to find out the service department is closed on Saturdays. They said they would try to reach there tech on his day off. Within a couple of hours they called to say it was ready. How does that happen? They rebuilt my master slave cylinder. Bunch of o-rings and labor. So again, thanks to you guys and a big shout out for Motosports in Hanover PA.
    From being stranded 350 miles from home to heading home with piece of mind tomorrow.
    PS: Progressive insurance road side asistence was another great experience. Picked up in 35 minutes, no deductible, safely flatbeded to the dealer.
    "THE DOG SLED"
    DMWMS Decal
    IPS w/
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Wow, that is an awesome experience.......more dealers like that would be fantastic for everyone.
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Mar 2014
    Southwestern Pennsylvania
    Smile Great spyder dealer
    Quote Originally Posted by spyder3 View Post
    My brother and I both got our 2014 limited spyders from them. Tammy and Ryan are good people.
