stranded in Gettysburg PA
Put on 400 miles since the clutch master cyclender was filled and bleed. Now it is doing the same thing. The fluid is gone, the clutch won't engage. Where is the brake fluid going? I see there is a dealer in Hanover. Any ideas? On top of everything else I have been sick in bed for most of the day. I'm 350 miles from home. Missed every ride on the rally.
"THE DOG SLED"
2011 Spyder Can Am RTS SM5 (Orbital Blue)
Nuvi 550 GPS With Ram Mount
Drink 2 Go Cup Holder
KewlMetal RT Run-Turn-Brake LED
GloRyder Wolf Paw (in blue)
DMWMS Decal
IPS w/
Alaska Leather Sheepskin Butt Pad
TricLed - Brake Pedal
I know nothing about the Hanover dealer but I do know that the dealer in Ephrata has a very good certified mechanic. That's where my bike goes and has always been fixed properly the first time.
Good people (Andy is service manager).
Very reasonable prices also, at least that has been my experience.
They are not to far from you either.
Hi, if you have or can download Roger's app
"Spyder codes" he has a list of all dealers in the state. Good luck.
Mortorsports in Hanover PA
http://www.motosportsinc.com/
Motosports Inc.
2117 Baltimore Pike Hanover PA 17331
Phone: 717-632-7093 Fax: 717-632-1404
I am told they provide good service, a number of folks from Baltimore go past the local dealer to get serviced up there.
Charles
![Quote](images/misc/quote_icon.png) Originally Posted by WA5VHU
Motosports Inc.
Charles
Had both my Spyders serviced there a few weeks ago. I was very satisfied.
- Rich
Let's see..!!
I would recommend rebuilding the master and slave cylinders. In some cases where there is a loss of fluid and it is black and sludgy refilling and bleeding is not enough. If none is leaking to the ground it may be leaking into the crankcase....good luck..!!
Sorry to hear of your troubles Good luck to you
formerly pman2011
Hanover Motosports provides great service. I purchased my 2014 from them and I traveled a little over 100 miles to get it serviced there bypassing 4 dealers that are closer.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
clutch
My bike is in shop for the same thing it is the O rings , piston in the clutch ass. Look up 2013 -5 service bulletin in the forum it was posted 2 weeks ago. You can fill it again with DOT 4 and make it home because they will not have the parts to fix it parts on order. Picking up my bike today. Good luck
![Quote](images/misc/quote_icon.png) Originally Posted by Chupaca
I would recommend rebuilding the master and slave cylinders. In some cases where there is a loss of fluid and it is black and sludgy refilling and bleeding is not enough. If none is leaking to the ground it may be leaking into the crankcase....good luck..!! ![thumbup](images/smilies/thumbup.gif)
Bingo, problem solved.
"THE DOG SLED"
DMWMS Decal
IPS w/
The dealer in Hanover, PA is exceptional . . . They will take great care of you.
Motosports Inc.
Charles
Just an incredible good experience with Motosports! Without notice I had my Spyder towed there only to find out the service department is closed on Saturdays. They said they would try to reach there tech on his day off. Within a couple of hours they called to say it was ready. How does that happen? They rebuilt my master slave cylinder. Bunch of o-rings and labor. So again, thanks to you guys and a big shout out for Motosports in Hanover PA.
From being stranded 350 miles from home to heading home with piece of mind tomorrow.
PS: Progressive insurance road side asistence was another great experience. Picked up in 35 minutes, no deductible, safely flatbeded to the dealer.
"THE DOG SLED"
DMWMS Decal
IPS w/
Wow, that is an awesome experience.......more dealers like that would be fantas tic for everyone.
Rewaco RF-1 GT
![](signaturepics/sigpic6685_9.gif)
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
Great spyder dealer
![Quote](images/misc/quote_icon.png) Originally Posted by spyder3
Wow, that is an awesome experience.......more dealers like that would be fantas ![thumbup](images/smilies/thumbup.gif) tic for everyone.
My brother and I both got our 2014 limited spyders from them. Tammy and Ryan are good people.
