Tire dimension tool for different specs
Here is a web address for comparing tire sizes. If our original 225/50/R15 size cannot be found, looks like
the 205/55/R15 is almost exactly the same except for width. (The other alternative, 215/60/R15 is quite a bit different.)
http://tire-size-conversion.com/tire-size-comparison/
DubuqueSpyderRyder
Additional comparison
Here's the specs for the 215/60/R15. Didn't show up on my first post.
DubuqueSpyderRyder
2020 RTL SE6
Spyder Rear Tire
DubuqueSpyderRyder
I changed my rear tire at about 12,000 to the Kuhmo AST 225/50-15, I like this tire it performs well in all weather conditions I
heard rumors that it might be discontinued but according to Discount Tire that was not a problem right now they have it in stock.
Mine has 12,000 mi. on it now and looks really good for another 12 But I went ahead and ordered one to have it avail. when mine needs replacing...Got it delivered for total cost of 81.00..Have it stored in spare closet inside house til I need it....
Freebob...
14rts
what about front 165 versus 175 did like rear specs thanks , matt 14rts cognac
Good to know..!!
very nice now if it could be a permanent picture in the upper right hand corner with an oil spec sheet below life would be simpler...
tire options
DubuqueSpyderRyder
I went with a nitto nt450 205/55/15R/ V . works very good and speedo and R
PM's the same as with junk kenda tire.
DubuqueSpyderRyder
I talked with a local tire guy yesterday about changing tire widths. Based on his experience and knowledge going from 225 to 215 or 235 would be no problem. That's evidenced here by all the guys who have gone with a 215/60R15. Going to a 205 or 245 is getting iffy, probably OK but not as secure as one size change. Going 2 sizes different, either 195 or 255 is a definite no-no.
Agreed. Going from the original 225 to the 205 is more than 3/4" narrower. Seems to me too that it is getting "iffy".
2020 RTL SE6
