Results 26 to 50 of 67
  1. #26
    May 2009
    Appleton, WI
    A good chunk of the '08's had DPS (dynamic power steering) issues and needed to be replaced. There was actually a recall. Make sure all the recall issues were taken care of. This may be the cause of the "orange gecko" and limp mode.
  2. #27
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    You can also purchase the service and repair manual from www.brpmanuals.com. $23.50 would be a good investment.
    You might also check to see if your dealer has a BRP certified technician. Many do not. If not, I suggest you find one that does.
    there are many on this forum who have many thousands of trouble free miles on Spyders of all vintages and models.
    2014 RTSS , Cogna/ black
  3. #28
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Electro_cat View Post
    So I put all the info on my first post. Which nobody reads ...
    Dump the SOB, its clear you will never be satisfied with it now that you've had so much trouble. Sorry.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
  4. #29
    I'll admit that my eyes glassed-over about a third of the way through your initial tirade...
    Ex-Winger... got that
    5K; I got that too...
    Pilot... ditto
    pissed off... gotcha!
    Now: How much actual riding experience do you have?
    Were you covering the brake with your foot?
    (Doing that can cause all sorts of fits within the electricals...)
    As a pilot; you're aware of just how fussy electronic systems can be.
    Something is setting your bike's off Big-Time!
    I'd look to the battery condition, ground straps to the frame, your foot riding the pedal...
    It's a process; you can get through it!
    Please just take it one agonizing step at a time, and let us know what you find; good luck!
  5. #30
    Mar 2012
    NJ
    I was thinking the exact same thing. ....[emoji57]
  6. #31
    Warwick, RI
    Default Spyder or 1980s Hyundai
    By chance, did someone install an aftermarket HID headlight kit on your spyder? The codes you see are the exact codes mine threw when I attempted to install a non-brp HID kit.... It stalled also and would not start.
  7. #32
    Jun 2010
    Las Vegas
    Look, Electro Cat, you come here looking for answers and you have been rather rude in your approach. You are expecting everyone here to give you answers but you don't seem to be looking for any on your own. You bought a 6 year old machine with 5,000 miles on it which means it probably wasn't maintained and hasn't had all of the updates.
    You have been given instructions on how to download the Owner's Manual, an app for looking up error codes and places to purchase and download a Service Manual. Now go read all of that and if you still have questions then come back here and ask them without getting rude in your replies. If you can't do that then you need to go to time out.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
  8. #33
    Thinks out loud
    Apr 2012
    Thumbs up
  9. #34
    Invalid Emails
    May 2010
    Milford,PA
    Default ......
    Starting to sound like a trolling expedition.....
    Orange Gecko = VSS Fault
  10. #35
    Feb 2013
    Halifax, Ma.
    Default WOW.....
    So did you read my post? I don't know how much more info I can give.
    Just got done reading the thread and have come to the conclusion that the young lady was looking for an instant answer, when there is none. And seems to have a little complex, thinking everyone is out to get her because she is a female.
    you folks went out of your way to help, I am not so sure I would have been so nice.
  11. #36
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Electro Cat,
    I could be wrong, but you don't sound like an Internet troll to me, even though your posts are coming off that way. You sound like someone who bought an older unfamiliar machine to ride, and it is giving you problems, making it undependable, and you very angry and frustrated. If indeed that is the case, then the people on this forum CAN and WILL help you, if you just cut back on the emotion, and give them the facts to work with. In that regard, Ann just gave you some very good advice. If you are serious about getting help, I would do what you can to follow it. And by the way, Ann would normally be one of the first folks here to help you.
    As was just mentioned, if you re-read this thread with a cool mind, you have ALREADY been given some very good advise on places to start looking. I'll just point you back to a couple of them....
    1. In post #15, spyryder gave you a link to the BRP website where you can download a manual for your machine in .pdf format. You SHOULD be able to do that with an iPad, or any laptop or PC. I'd try again.
    2. In post #27, jvicker addressed the DPS fault and mentioned that it was prevalent in your model year. Someone else said that could be caused by corrosion in the electrical system, which could be quite likely in your case. (Also, in your original post, could you have meant "vss" rather than "fss"?) These may well be the places to start the discussion with a good Can Am repair facility. And that leads to the third post I'll point you to...
    3. In post #24, IndyRSS gave you some very good advise about how to seek reliable help in your location. I couldn't agree more with what was said there. As has been stated, these are complicated machines run by a rather sophisticated computer (the ECM). It generally takes a BRP certifed technician to diagnose complicated problems like yours, and they have the computer software available to read a lot more from your machine than just the fault codes. You list your location as "Twycross". If you are in the UK, you may have fewer dealers with certified repair shops to choose from but there are a few dealers listed within 100 or so km of you. If you are not in the UK and could be more specific about your location, someone will point you to some good repair facilities. Also the BRP website contains a dealer search engine.
    Best of luck getting your problem sorted out. Sorry to be so verbose.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
  12. #37
    México
    Default Ufff....
    Too much bitching IMHO ..to me this is a friendly forum to express your needs and if help available great, if not, well you have you look in other places but NOT be ps´off at the forum´s member. Personally I did not know that you were a female and actually that is not relevant (fem vs. male)...I am new at the Spyder experience but NOT NEW on forums or motorcycles. Think that and like other colleagues stated, you got a bad used unit and it can happen to any of us. I just returned to the dealer my 2014 BMW R1200RT-LC with ONLY 3800 kms bc of a recall so if that happens to a new unit, more to an used unit with many years on its belt. Don´t get offended by my opinion and if you were close I would help you sort out your Spyder problem. Greeting from Mexico and SMILE....
  13. #38
    Default WELL.WELL.WELL
    Quote Originally Posted by Jerbear View Post
    .....................X A SKAJILLION ......mIKEGUYVER
  14. #39
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default lady spyderlovers
    EVERYONE BE SURE TO READ ELECTRO CAT'S MEMBER INTRO. ON THE LADY SPYDERLOVERS PAGE. YOU'LL BE VERY IMPRESSED.
    it was fun while it lasted.
  15. #40
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    yep....TROLL....probably won't hear from her again.....I mean, hope not....
    2008 GS.....PE # 2888
  16. #41
    Jun 2013
    Milford, Ohio
    I think that you need to work on your personal issues before you worry about fixing the Spyder. If you have treated it like you have the people on this site that are clearly trying to help you then I understand why it doesn't run. I can only guess how thankful the dealer is for your purchase. Lol.. If you want help then ask for it, listen to what is offered and act on it. After all your a pilot, electrical engineer and god only knows what else so use all your knowledge to figure out people skills. Then please come back and enjoy the site and your Spyder.
  17. #42
    Mar 2012
    NJ
    ElectroCat,
    Where are you located?
    I agree that you should dump that non-running POS. When you get a sec send me a message and maybe we can work out a deal and I will take that POS off your hands. I've got a nice stack of cash to bring your way that will likely better suit your needs vs. That non-running spyder.
    Doug
  18. #43
    Quote Originally Posted by coz View Post
    ...And I thought that my own manners were bad...
    I actually thought that I was trying to help with the info that I gave...
    It appears to have been wasted.
  19. #44
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by DrewNJ View Post
    ElectroCat,
    Doug
    My 2008 is running fine. How about offering me some of that stack for my spyder? If it'll help, I can become rude/insulting.
  20. #45
    Yes folks, the intro seems to say it all.
    Mar 2012
    NJ
    Quote Originally Posted by wyliec View Post
    Haha...no insults needed. I'm looking for a basket case machine to do an RSV swap with.......unless your selling cheap!
  22. #47
    Jun 2010
    Las Vegas
    Shame on me, I assumed that Veronica (1 c) was a guy.
    Ann (no E)
    2010 RT- 622
  23. #48
    Dec 2008
    Syracuse, NY
    Sorry, no can do.
  24. #49
    Mar 2012
    NJ
    Sorry, no can do.
    Believe me, i understand. [emoji41]
  25. #50
    Very Active Member Mike,P's Avatar
    Sep 2011
    Wales , Michigan
    Cool
    I've come to the conclusion,, I'm GLAD she doesn't live at my house
Tags for this Thread
