Results 1 to 16 of 16
Thread: Color change
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    Default Color change
    All the talk about plasti dip I have read made me think. I really love the white spyders so why not just have one and well for $38 she looks pretty dang good to me!! Just wanted to share the photo. Yellow to white.
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Do you have any "Before & After" shots?
    Looking good
    Jun 2014
    People's Republic of NY
    Wow, that's plastic dip?
    Can you describe the steps
    Looks cool.
    Aug 2013
    United States
    Did you take off the panels?
    How long did it take you?
    Looks great!
    Sent from my SPH-L900 using Tapatalk
    Jun 2014
    Quote Originally Posted by fas2000 View Post
    Looks great!
    What he said
    Apr 2011
    GREENVILLE, SC
    Default STICK
    OVER TIME, HOW WELL DOES THIS STUFF 'STICK' TO THE OEM FINISH.....????????
    LOOKS GR8 BTW.....
    DAN P
    EASLEY, SC
    SPYD3R
    Jun 2012
    Brandon, MS
    Unfortunately I did not take any photo's during the process
    Jun 2012
    Brandon, MS
    Looks great!
    I removed the side panels and removed the upper portion behind the seat, but was able to leave the frunk and all fenders on. I simply used a sheet to run between the tire and fender to cover all areas around it as well was able use the same sheet to put between the frunk and windshield area. Oh yea also removed the flaps on the front fenders. It took me roughly 5 hours total. The great thing about all this is if you mess anything up or get the coating somewhere you didn't intend to it simply will peel right off or rub off if it's just slight overspray. They have a can called "pearlizer" which I may also try which Would be a clear coat top layer that would create a white diamond appearance. This stuff is a lot of fun to fool around with and if ya don't like it it takes about 5 minutes to pull it all off.
    Thanks for all the compliments as well, I really like the white!
    Jun 2012
    Brandon, MS
    Quote Originally Posted by SPYD3R View Post
    LOOKS GR8 BTW.....
    DAN P
    EASLEY, SC
    SPYD3R
    I have read here on the forum that some have had it on for years. My neighbor plasti dipped his car after a bad hail storm hit here and had it on there for almost a year so for me only time will tell
    Brookhaven, MS
    Looks great!!
    Aug 2013
    United States
    Thanks for the explanation. Looks great. If you apply the clear coat you mentioned please post pics. The white looks nice. But your yellow was equally nice. I was thinking a burnt orange shade myself.
    Default Nicely done..!!
    looks amazing and quite different to the one in your avatar...congrats I'm sure your very pleased with your handy work....
    Jun 2010
    Las Vegas
    Looks great
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2013
    Delaware
    Looks great
    that paint works great I painted the bottom of my jeep with that stuff and seems to be holding up very well.
    Jun 2011
    Near Lexington, NC
    LOOKS GR8 BTW.....
    DAN P
    EASLEY, SC
    SPYD3R
    It sticks very well as long as there is no rubbing against it, such as your feet when you get on/off. I had used some RED on my white bike to liven it up and in the process put a large "splash" of it on each side down below the seat. Turned out, it was in a place where the passengers right foot, getting on/off, just naturally lightly rubbed that area and it soon began to peel. The whole section was easy to peel off. Its fun stuff to use, not as messy as regular spray paint, and if you don't like it, peel it off. About $6 a can at Lowes.
    I used some BLACK to paint the nose scoop area of my 1330, down under the frunk, and its held up nicely. I had expected that bugs and other debris might cause it to chip but so far its held up.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
