Won't Down Shift Automatically
Wife's 2009 RS S5 sometimes will come to a stop without automatically downshifting into 1st gear. While she's waiting at a stop light it will gradually work its way down to first gear. It does down shift manually.
Any thoughts on what's wrong? Thanks.
Little checking..!!
these machines are very oil sensative. Your having the auto clutch makes it even more so. Check oil level as indicated in the manual. Make sure you change oil and both filters at appropriate intervals. If this does not help you may have to dig deeper may need adjustments the dealer would have to make...
If not oil, possibly leaking vac hoses on left side. Theres been several threads about this.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
as they said oil level must be at the top or it wont shift right,the oil is what makes the shifts so if loe just a little it wont work right.
Check the shifter lever just under the bottom left side tupperware. In front of the foot peg. It could be loose and trying fall off.
Thanks a lot all. I'm on vacation for a few weeks and will look into this again when I return.
Mike
