Results 1 to 24 of 24
    Invalid Emails
    Jul 2011
    Kernersville NC
    Default Rear tire mileage
    First rear tire replacement on a 2011 RS SM at 16,507 miles....good or bad...?
    Default Well..!!
    your on the high side. That is good I got 19,800 miles but rode it down to the limit. Some have gotten more many less and the 2014 RT's close to nothing. I just put anither Kenda on lets see how it does...!!
    Vermont
    I have a 2012RTS-SE5, I have 7,748 miles, and showing the first ware bars on my rear tire. Is this good or bad?
    Deanna777
    I have averaged 15K on the rear tires. From my perspective, your doing very good.
    Vermont
    Should I try for 10k on tires before I put on new tires?
    Deanna777
    Deanna777
    It all depends on how worn "your tires" are. I don't like riding on bald skins, so by the time my wear bars are starting to show some wear, its time for another new one.
    We are currently watching the 2011 carefully. 13K miles so far, but the tire is "getting there."
    Nov 2013
    Lutz, fl
    We have a 2010 rt with12,000 on it now, with probably 3,000 to go.
    At over 16,500 miles: Outstanding!.jpg
    Dee,
    The tires will become more prone to hydroplaning as the center tread wears down... If you ride much in the rain; keep that in mind!
    Vermont
    So I should just keep an eye on the tires. Deanna777
    Vermont
    Dee,
    Bob: yes, I will keep that mine about hydroplaning. Deanna777
    I agree with "AK"; it's better to keep good tires on a bike, than risk the consequences!
    Invalid Emails
    May 2013
    Butler County, Western PA
    Quote Originally Posted by Rayelljay View Post
    Wow.....I would have been thrilled. I only got a little over 8000 on mine.
    only 7,000 mile, on my OEM...
    Nov 2013
    Oro Valley Arizona
    A lot of tire wear depends on how you ride and how much air you carry. Jack rabbit starts each time you startup will surely cause the tire to wear quickly. Some states also use different and more abrasive materials to build there roads.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Default WEAR BARS
    Dee,
    ....Bob rest assured Dee's tires are fine .......the " WEAR BARS " she is referring to aren't the ' wear bars ", .......Mikeguyver
    Aug 2012
    Central Coast, CA
    That's outstanding mileage from a stock Kenda. Of course, that all depends on how it looked at that mileage.
    Invalid Emails
    Aug 2010
    ohio
    2014 5400 miles. Just got back from the smokey mountains. 2120 miles in 7 days and no interstates. Rear tire is now junk. Darn twisties. Darn torque. Darn fun. Anybody know of a dual compound tire that will fit? I am looking at the Kumo right now.
    Active Member Farmbanker's Avatar
    Sep 2012
    Alburnett, Iowa
    Ok, I have just about 9k on my back tire. As I face the machine from the rear the right half of the tire is much more worn than the left side. Not much left as you can see from the pictures. I assume before I go to Sturgis this will need to be replaced....anyone think I can get another couple thousand out of this? I'm also assuming alignment must be off for this kind of wear?
    Looks like I will be getting a car tire for this as well. Now to decide on which one........
    Red 2016 RTS, Diamond R Armrests, Ram X Mount, Doc Humphreys Dampener, BajaRon Swaybar, Spyderpops "Critter Splitter"
    "It is the common fate of the indolent to see their rights become a prey to the active. The condition upon which God hath given liberty to man is eternal vigilance; which condition if he break, servitude is at once the consequence of his crime and the punishment of his guilt." John Philpot Curran 1790
    Default NOT LOOKING GOOD
    Quote Originally Posted by Farmbanker View Post
    ......If that's your rear tire ( and it looks like it is ) ....this is not a good thing.....I haven't heard of a rear tire wearing more on one side .................Usually the rear wears in the middle first.! ! !.....Mikeguyver
    Apr 2008
    pennsauken nj
    Default tires
    Just replaced all three original tires on my 2008 spyder, @ 22500 miles, and original battery.
    May 2012
    pell city alabama
    Default Rear Tire
    I replaced my rear tire @ about 10,000 miles. could have gotten a little more but..... I couldn't help but wear it out faster You are doing good.
    Banged Up Member
    Dec 2009
    Sanford, Florida
    ​Good
    Thinks out loud
    Apr 2012
    Lightbulb
    Just a thought. As I recall, you had to have some engine work done early on. If, they pulled your engine. They may not have realigned it properly. There is a special tool for doing so. Should that be the case? Then adjusting the drive belt to compensate for improper engine alignment yet have the belt track properly, could be the cause of excesive tire wear on one side.
    Jul 2013
    Central, NY
    6,100 miles on mine and won't pass inspection, I ride it pretty easy - 50% of the time is two-up - putting on a Kumho Ecst AST next week.
