Cruise Control from Australia
Is anyone is the US using this Cruise Control from Australia?
Available for SM5 or SE5 at $589 USD.
http://www.mccruise.com/Can-Am-Spyde...ise-p-161.html
The mccruise is the Rolls Royce of cruise controls...I haven't heard one negative comment about it.
I can't afford one...I went with the throttlemeister, which is a mechanical 'cruise'...more-so just locks the throttle so that you can rest your hand on longer rides...it's weighted as well...so you get less vibration and a nice cruise effect (provided the roads are more flat)...
If you have the money, the mccruise is awesome...if you're not 100% handy, you might want to have someone else install it...don't want to fiddle around with installing a cruise control as if there is a mishap, it could be rather bad...then again, that's what I would do...
I have it and absolutely love it! My dealer tried all kinds of ways to try to get it to stick or trip up, and it would cut itself off if speed conflicted with the Spyder's safety features. It will also cut off if you have to twist the throttle hard or if you pull in the clutch as well as hitting the brake.
I have it, use it whenever I am on the long road, and it WORKS...
Yes, a bit expensive, but so are other great mods. Of course that is my opinion.
