Error Codes
I have that silly check engine light that comes on sometimes, turn the key off and back on and it goes away. I saw a post about how to get the error codes by:
Start engine->hit mode until total hours comes up->flash high beams 5 times. I have done this many times and no codes.
Is this accurate or do I need to take to dealer to hook up to buds. I have had some oil "issues" that I got all fixed tonight and wondering if there was a pressure issue.
Anyone have some thoughts on how to get the error codes?
Try this - turn the ignition switch on , clear the warning message with the mode button on the left handlebar, then use the mode button to select the "Hr" mode, then depress the headlight override switch on the right front handlebar and the mode switch on the left front handlebar at the same time. While holding these two buttons in, quickly hit the high beam button on the the left grip five times within 2 seconds. Any messages should scroll across the display. (I don't think you need to start the engine.)
I have the same problem and then the motor started to cut out. I have not tried the code thing I will try it when I get home> The bike has about 3600 miles on it
Oh my...how did you figure that out?
