Results 1 to 25 of 43
    Jun 2012
    Clemmons, NC
    Question RT Humming Any Ideas?
    You know that sound when you turn the key? Sounds sort of like a fan hum then shuts off and you start your bike. Well I am hearing that humming sound constantly. It almost sounds like its coming from the back but I am unsure. I will take it into the shop Tues. but had a little further to go today. Any ideas ? All temps and gauges shows fine.
    Jun 2012
    Hampton, Virginia
    Post
    14 RT...probably the fuel pump...mine whines (more of a whine rather than a hum to my ears) as well. My dealer tech says it's the fuel pump. Believe I read a post by one SL that had the fuel pump replaced under warranty but the replacement pump whined louder than the original one.
    Active Member Guzzi's Avatar
    Jun 2012
    New Smyrna Beach, Florida
    Quote Originally Posted by SpyRyd View Post
    That was me! The replacement pump has been worse and louder than the original. Have been harping at the dealer for 2 mos now. Got a call last week and a new pump is being shipped to the dealer for my 2014 RTL. Factory told the dealer that they received a bad batch of pumps and guess what; my original was faulty, and the replacement was also in the same batch. Now waiting on the third new pump. Sure hope this one don't sing to me loudly anymore. It has been really irritating. If you suspect your pump is giving you the same problem, tell your dealer, as you may have one of the faulty pumps. By the way, none of the pumps have failed; they are just very loud and whine away at any speed.
    GUZZI :
    2020 RTL blue
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    Quote Originally Posted by Guzzi View Post
    Dose the sound change with the rpm's of the engine?
    Ours has had a whine or growl since we got it but since the 3000 mile service it hasn't
    been as bad but can still hear it some.
    Toby
    2020 RTL
    Oct 2013
    Austin, TX
    Quote Originally Posted by saint999 View Post
    Try to sing along with it?
    Seriously though, this has been talked about, and almost every RT has this sound. It is nothing to be alarmed about.
    Nov 2013
    Central Texas
    Our 2013 RT LTD SE5 whines when the key is turned on. I have always thought that it was the fuel pump loading up, never hear it when riding or when shutting down.
    Default Sounds like..!!
    the fuel pump..good exhaust system will drown thst right out..!! if not one of the faulty one can the warp it..??
    No, but if you can get it to whistle Dixie you've really got something there!
    Jun 2013
    Try to teach it the words . . . that might stop the humming . . .
    Coolidge Arizona
    I had a very loud whine and a very loud growl
    Got rid of all the noise when I got divorced
    Jun 2012
    Clemmons, NC
    Default Yep
    Yeah thats what this one sounds like. Small jet engine going on in the middle of the bike. Not too loud now but concerning. It didnt do this till about the 800 mile mark.
    Jun 2012
    Clemmons, NC
    Default Yep
    Your right more of a whine then a hum. It sounds like a tiny jet engine at idle. Is your dealer going to replace it ?
    Jun 2012
    Clemmons, NC
    Default I may just may
    I may try some seafoam on my next fill up before Tuesday. See if running some fuel cleaner will help the noise some. Hope this is nothing to be concerned about, my dealer doesnt like to replace anything till it dies and I dont like that too much. Can leave you on the side of the road philosophy.
    Jun 2012
    Hampton, Virginia
    Post
    Nope. Kinda got the impression from the tech that "they all do it". Gonna have them contact BRP to see if there is something coming out on "bad fuel pumps".
    Banged Up Member
    Dec 2009
    Sanford, Florida
    Quote Originally Posted by Rattigan_Roger View Post
    I believe the sound is the purge pump.
    Take heed of what he says.
    ​Chris
    Jun 2012
    Clemmons, NC
    Cool
    What is a purge pump?
    Banged Up Member
    Dec 2009
    Sanford, Florida
    The following is taken from NancysToy in an earlier thread. Perhaps this might help.
    Gas fumes have to be vented from the gas tank, especially as the tank heats and the gas vaporizes, building pressure. The tank also has to be vented to allow air to enter the tank as the fuel level drops. Because any air exiting the tank contains hydrocarbons that are consdidered to be environmentally harmful, the EPA demands that the tank emissions be recycled or limited. The canister contains activated charcoal, which can absorb the harmful vapors. Any that are released are recycled through the intake when the engine can suck them in and accept them, via the purge valve. When the engine is off, the purge valve solenoid opens the atmospheric vent and directs these gases to the atmosphere...or allows air to enter the cooling fuel tank so it doesn't collapse. Think of the evap canister as a wide spot in the line that contains a sponge of sorts.
    ​Chris
    Active Member JimFoy's Avatar
    Aug 2012
    Farmersville TX
    My 2014 RTL hums too. It is continuous when the engine is running, and does not change in pitch -- it's about F above middle C. It's annoying.
    So far; we've got Whines, Hums, and Swishes...
    What's next?
    Jun 2011
    Near Lexington, NC
    Default How about some "Whaa Whaa Whaa" at running speed?
    The whine I hear at idle increases as the speed increases and when cruising steadily there's a monotonous repetitive sound like "wha, wha, wha." Would the purge valve be making that sound? It sounds mechanical. I had a good many miles on mine before I started noticing it. As said above, "they all do it".
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Nov 2013
    Oro Valley Arizona
    ​If you could name the tune it is humming perhaps it would quit!
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Apr 2010
    Ontario, NY
    Humming hmmmmm...perhaps it doesn't know the words. Sorry I couldn't help it.
    Jun 2012
    Clemmons, NC
    Smile Comedians
    You are all funny and I did get a laugh. I did take this to the dealer and they confirmed it was a very loud fuel pump but since BRP has no noted failures they won't replace it. I dont want to be the first failure on a long trip though so what to do?
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Mine does it but I can't hear it....my son complains about it though.
    Jun 2011
    Near Lexington, NC
    If you want to compare it to mine, lets meet up somewhere. I'm down in lower end of Davidson County on Rt 150, retired, so can meet anytime, anywhere. Otherwise, I think you can tour with confidence; theres hundreds (thousands??) of '14's on the road and I've not read of any failures. Mine hummed and went "wha, wha, wha," flawlessly 2200 miles out to Springfield Mo and back with 2700 mi on the clock. 7700 now and no issues other than "DESS" popping up occasionally when I turn key on.
    Thinking about it, maybe we need to organize a weekly Can Am meet for breakfast somewhere in the Triad area.
    If anyone is interested, PM me.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
