Spyder not starting...Help
Hi. I have a Spyder RS SE5. Went out to start it and the oil lamp indicator came on and it would not start. Checked oil added oil and tryed again. Still does not start. Could you please tell me what I need to do?
Is it in neutral? If not step on brake and try again.
Check to make sure kill switch is not in stop position, make sure it is in natural, put foot on brake and try to
Start
![Quote](images/misc/quote_icon.png) Originally Posted by Rando
Check for codes.
How do I do that?
![Quote](images/misc/quote_icon.png) Originally Posted by samewok
Yes it is in Neutral. Still won't start.
![Quote](images/misc/quote_icon.png) Originally Posted by Silvervette05
Start ![thumbup](images/smilies/thumbup.gif)
Kill switch is not in stop position,it is in Neutral,put foot on brake, and it still will not start.
![Quote](images/misc/quote_icon.png) Originally Posted by Appylover
How do I do that?
Get this app.
http://www.spyderlovers.com/forums/s...t=Spyder+codes
How do I do that?
Little checking..!!
when was the last time you started it..??
It's in neutral..check
Your foot is on the brake..check
Your kill switch is run position.. Check
You pressed the mode button to clear the screen..![don't know](images/smilies/shrug.gif)
You pressed the starter button..ckeck..does it click..?? Does it turn over..??
Try to jump start it..if it starts then your battery needs help.
![Quote](images/misc/quote_icon.png) Originally Posted by revjvegas
Tried that but nothing came up. Oil icon still lights up.
Is it cranking and not starting or not cranking?
![Quote](images/misc/quote_icon.png) Originally Posted by Chupaca
You pressed the mode button to clear the screen.. ![don't know](images/smilies/shrug.gif)
Try to jump start it..if it starts then your battery needs help. ![don't know](images/smilies/shrug.gif)
Will try to jump start it tomorrow. I have to figure out how to do that first. Don't have anybody around who can help me. But I do have jumper cables.
When I press the start button the only thing that happens is the gauge cluster lights up then it goes off and the only thing lit up is the oil can icon but does not start.
Last time I started it was two and a half weeks ago.
Oil can light
The oil can light illuminates when you turn the ignition on.
Sounds very much like you have a flat battery. you have a couple of options:
Jump start
Charge battery
Check battery connections
Hope you get it sorted.
![Quote](images/misc/quote_icon.png) Originally Posted by billrob71
Not Cranking.
![Quote](images/misc/quote_icon.png) Originally Posted by NZSpyderRyder
Jump start
Charge battery
Thank You..
+1
Takes little voltage to lite the cluster but a lot of voltage to crank the bike , half to start with the basics first.
Can I jump start my battery with my car?
Yes that is what the jumpstart points are designed for. If you have a 2012 or older the jumpstart posts are under the seat. If you have a 2013 or 2014 you have to open the front trunk and then remove the left access panel.
The instructions are in your owners manual.
![](signaturepics/sigpic7798_4.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by billybovine
Yes I have the 2012. I got it jump started and it started right up. Let it run for awhile before I turned it off.
Thank You
Wanted to tell everybody thanks for all your help
Very good, I would go to one of the auto box stores and have the battery and charging system out
How much oil did you add? Not using the correct sequence to check the oil will give VERY inaccurate readings...
![Quote](images/misc/quote_icon.png) Originally Posted by msj4848
good point, and you're supposed to add and check oil after engine has been running!! if you added it cold engine, most likely too much was put in!
