Results 1 to 7 of 7
    Feb 2014
    Green River,Wyoming United States
    Default key stuck in ignition Help
    I was out riding several errands came back home went put to spyder rt and key will not turn in the ignition switch will not turn left or right or push down and key is stuck Help
    Default Interesting..!!
    gotta ask..is it the spyder key..?? Roger is right, tapping it and lubing it should help. There is an issue with the ignition switches on the 14's some need replacing. Hope the jiggle and oiling helps...
    Feb 2014
    Default it didn't work!
    Yep, it is a sypder key. I tried both, jiggling and sprayed wd 40...nothing working. cannot turn, on, cannot move it..cannot pass go
    Thanks for your help....looks like maybe roadside assistance and a call to the dealer tommorrow.
    Wierd...it was working fine, went for a ride 10 minutes later.....problem.
    Active Member CentralCoastCA's Avatar
    Aug 2012
    Santa Barbara County, CA
    BRP would not ship my RT from the factory until they checked and/or replaced (if needed) the ignition keys because there were several reports of the keys sticking. I don't think there was a recall, per se, but an "update" notice sent to all dealers about the key problem.
    Hope you don't have to wait long to get it fixed and back on the road.
    Here is the thread that discussed the sticking keys:
    http://www.spyderlovers.com/forums/s...rvice-Bulletin
    Feb 2014
    Thanks for all the info at least it happen at our home and it is safe in the driveway for the night
    Feb 2014
    Default key is out
    Thanks to my Son he got the key out after playing with it for 10 minutes of the ignition and I sprayed or flooded it with Houdini 4 way lock lubricant. Now it goes in and out like a hot knife in butter.
    Invalid Emails
    Jun 2008
    alabaster al
    Default KEY
    Mine did that today at Walmart, had a screw driver in rear truck took handle and warped hell out of it on top of key.Stared working right.
