First Oil Change on the 2014 RT
This is so much easier than the 11!. Still 2 drain plugs but easy to get to and drain cleanly. One filter that comes out the top and also clean by simply wrapping a rag around the base of the top cap before pulling the filter. To put the O rings back on the one drain plug (the other only has a single crush washer) I wrapped the threads with electrical tap first so the O rings would slide/roll up with getting damaged by the sharp screw threads. Voila', 45 min oil change! No fuss no mess.
One odd thing, the left hand drain plug is a 45 Torx head, the other is an Alan head. No biggie, just something thing to watch for.
Pretty sure they are both Torx: one 40, other 45.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I took mine out and looked under the light before I put it back on, it is an Alan head on the one side but I will check again to be double sure next time.
? just one filter,no transmission filter? I've not looked at Sofia's new '14RTL but assumed it had two filters just like the 998.
Yep, just one filter.
The SE does have 2 filers just like the 998's. The transmission filter is just not changed when you change the oil. Just like your automotive.
It does..!!
have a transmission filter but it is not changed with regular oil changes. It is in the maintenance schedule and is rather expensive...glad you were able to do the change yourself and pass on these helpful hints...
How many miles did you have on it before your 1st oil change? What condition did you find the oil (mine is still very clear and "fresh" looking at 1000 miles. Did you discover any metal filings during the change?
Thanks for posting this info!
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
I changed mine at 4,000 miles and the oil looked good, it hadn't used any. There were metal filings on the magnetic plug but not an unusual amount. I thought the oil change was a bit of a pain since you have to remove a lot of Tupperware.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
SpyderLovers Sponsor
Plug differences
Yes, for sure. One plug a torx, one an Allen! Remove mirror, air wing, side panel, acoustic panel. 36mm on filter housing, same as rear axle. Relocate the bottom panels that are underneath to a shelf in the garage. Easy.
Joe Meyer
The oil was dark with very little filings.
