HMF EXHAUST
I want to put HMF exhaust on my 13 rs but not put fuel optimizer. Does anyone know if I need this. If so is there exhaust out there that doesn't.
THANKS
Hard to say..!!
I run a hindle exhaust and JT's air system and no fuel controller. HMF has different models but if you stay away from the competition models you should be fine. Maybe there is someone running an HMF without a controller. Many shop just automatically tell you you need the controller...
I have an HMF on my 2013 RS. They only have one option for the 2013's so it makes pick one easy. You will not need any other mods and it is an easy swap. I've got about 1500 miles on mine and love it.
We ran for awhile on a 12' and an 11' both with HMF exhausts and no additional fuel manegement. No issues.
Is yours an SM or SE? We have had some decel popping on SE machines, but it's not anything that is going to hurt anything. Just annoying.
Sent from my SCH-I545 using Tapatalk
+1 on the HMF
the hmf sounds great. if i were to buy a factory made pipe, it would be the hmf. excellent bang for the buck.
![](signaturepics/sigpic7177_92.gif) it was fun while it lasted. ![biker](images/smilies/doorag.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by DrewNJ
SM5
THANKS
Hmf have a great sound and a better price. 10,000 miles on my HMF without any juice box and no issues. I get a little backfire laying off the throttle when its hot out +85.
Sound is not obnoxious is . Would not probably be good to wake neighborhood
![Quote](images/misc/quote_icon.png) Originally Posted by bmccaffrey
SM5
THANKS
Do it! You won't be disappointed.
Sent from my Venue 8 3830 using Tapatalk
Watch the clearance of the pipe and the parking brake pulley on the right side of the rear wheel. The HMF pipe installs pretty snug to the bike...which I personally like but if your not careful you can install it in a way that it will hit when the suspension compresses
![Quote](images/misc/quote_icon.png) Originally Posted by ssmcclub;install09664
Did you have to install a shim as others have suggested i believe they said 1 1/2". Or just use hardware included
no shim
no shim just the hardware included
richie spyder ![wink](images/smilies/icon_wink.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by Colin
Put It on tonight sounds good gut thought it would be a little louder. Does it get a little louder as it breaks in ![Gaah](images/smilies/gaah.gif)
Probably the only way to get it a little louder is to remove the Cat Converter, the 2013s have it before the Muffler. Lamonster does one. I have one being made for my 2013 ST SM5 with an Akrapovic.[/QUOTE]
Mine has gotten louder after about 1500 miles. It is louder, but still not obnoxious.
how to make your pipe a little louder
run the bike up to 110 a few times. that should do it.
The cat muffles the sound quite a bit.
i think doc doru holds the spyder speed record of 123. the cat does keep things kinda quiet. it will get a little louder over time. or just ditch the cat.
So how is the HMF pipe working out for you, have you gotten it installed yet? I really like mine, just curious what you think.
