Results 1 to 24 of 24
    Invalid Emails
    Jul 2010
    Central Connecticut
    Default 2014 RTL - Can't remove gas cap !!
    I went to put gas into the RT today for the first time. When I turned the gas cap counterclockwise to remove it, there was a ratcheting sound just like when you tighten it. I tried pushing down on the cap and turning, pulling up on the cap and turning, turning it clockwise, etc. and all it does is free wheel around and around!
    Of all the stupid problems to have this has to take the cake. I'll obviously be calling my dealer tomorrow and bringing it in. Hope I at least have enough gas to get there
    I'll keep you all posted.
    Oct 2013
    Austin, TX
    That is strange, but of all the problems to possibly have, that would be one of the much less disturbing ones. A gas cap replacement is a easy and non-intrusive repair. I'm wondering if so much pressure has built up in the tank, that the cap can't be removed? I know I've taken the cap off a few times and heard a major hiss. I also wonder if a generic cap from Wal Mart could be used as a replacement (as a quick and cheap solution to your problem).
    Nov 2012
    North Las Vegas, NV
    Probably drill a small hole through the top and bottom plastics and you would be able to turn the cap off using the drill bit or a stiff piece of wire to keep them both turning.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default Bummer..!!
    have seen this a few times. Seems some caps have a problem with the ratcheting system. If you squeeze the cap you can usually get it off. I know most push down or pull up but doesn't engage the ratchet squeeze it like jucing an orange and twist then get a new cap...
    Try giving it a nice TOUGH squeeze from the sides...
    And a generic from Wally-Mart can hold down the fort, until replacements arrive!
    Good Luck!
    Active Member va2djd's Avatar
    Apr 2010
    st jean sur richelieu
    Use a paire of plyer to squeeze it
    Spyder RT LTD 2018 SE6 ASPHALT GREY METALLIC - DARK EDITION( Wife)
    Spyder F3T 2016 LTD Black Special Édition
    French Spyder Forum
    SpyderTeam Rive-Sud MTL
    Facebook
    https://www.facebook.com/groups/spyderteam/
    Twitter
    https://twitter.com/SpyderTeam_ca
    Nov 2012
    North Las Vegas, NV
    Maybe some channel locks
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Invalid Emails
    Jul 2010
    Central Connecticut
    I tried squeezing the gas cap. No can do - either with or without tools. I'm hesitant to apply too much pressure - fearing that if I actually break it my dealer will say: "Well....you broke it....how is that a warranty issue?".
    If you could get a video of it NOT working; show it to him and ask what HE would have done.
    Breaking something that's already broken... shouldn't count against you.
    Just DON'T crush the filler spout of the tank!
    Apr 2012
    Florida
    Pictures and video. Also call the dealer before trying with tools. Tom
    2020 Petrol Blue Metallic RTL
    Invalid Emails
    Jul 2010
    Central Connecticut
    Default That was easy!
    So...I rode into the dealer this morning. The salesman couldn't open it, one of the techs couldn't open it either. Then the Sr. tech comes out...puts both hands on the cap, pushes down hard with his body weight, twists....and voila! Cap comes off. Guess I was just too gentle on it. I had tried pushing but not with body weight behind it.
    Well at least I wasn't alone feeling stupid LOL!
    Turns out the cap was indeed broken inside. You could hear little pieces rattling around in it. The filler neck was fine. Gave me a new cap. In/out in 10 minutes max.
    THESE types of problems I can deal with!
    Oh yeah.....I did fill up on the way home..no problem
    Thanks for your suggestions
    Glad to hear that you can get gas now!
    Bryant, Arkansas
    anything made by man can fail at any time, hope you enjoy your new 2014, I now have over 6,000 miles on mine and love it.
    Cruzr Joe
    Jun 2011
    Near Lexington, NC
    I don't have a lot of strength in my hands and mine was very hard to open; nothing broken, just hard, took both hands to get it off. I swapped the rubber gasket with one off a spare cap that seemed softer and have had no more problems.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Jun 2010
    Ferndale, Washington
    Glad to hear a happy ending. You could have been miles from a dealer with the stuck gas cap and an empty tank.
    Sep 2012
    Maynardville,TN
    Good deal
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Default Our Cap Stuck Too!
    We were coming back from visiting relatives on a 225 mile run and stopped for gas and the cap would not come off. It just clicked, it was harder to turn counterclockwise than the normal clicks clockwise but it would not budge. I tried pushing, pulling, squeezing and even giving it a little help from some of the different Leatherman tools but it was stuck. Fired the engine back up a couple of times for a couple of minutes each to see if relieving some pressure or vacuum would help but no. After about 40 minutes I gave it another try and it clicked a few times and then slowly started coming off. After filling I screwed it back on and stopped after a couple of clicks then unscrewed it and it came back off like it was greased with butter, no resistance to speak of. The temperature was around 90° and I think it may have pulled a vacuum. Anyone else ever have this happen?
    Charles
    Glad your gas cap issue has been solved.
    Aug 2012
    Central Coast, CA
    After reading about these gas cap issues I no longer tighten beyond snug.
    2020 RTL SE6
    Louisville, ms
    Default gas cap problems
    Quote Originally Posted by mindman View Post
    I had the same thing happen to me on the second tank refill 2014 rts, Had to get off with a large pair of channel lock pliers, took about a month and a half for dealer to send me a new gas cap, in the mean time the cap got harder and harder to get off with vise grips so I went to local NAPA store and matched one up, the new cap came from the dealer the next day and no problems so far needless to say I still travel with a large pair of channel lock pliers in the frunk.
    May 2014
    Texas
    Quote Originally Posted by Mikesm View Post
    Same here used large channel locks to get it off... My dealer had 3 in stock... no charge...
    Mar 2012
    NJ
    Quote Originally Posted by KX5062 View Post
    Me either. If it clicks, it's to tight.
    Just snug it.
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default have to
    if i don't give it a quarter turn past when the clicks start, it will loosen itself completely. how about THAT ?
    it was fun while it lasted.
    Jul 2010
    KILLEN, AL
    Quote Originally Posted by bgame View Post
    Large channel locks and tremendous effort worked for me. The cap spins freely both ways - won't go on or come off without channel locks. I only have 1500 miles on it.
