Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
  1. #26
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Bumblebee67 View Post
    Perhaps these might be worth a try???? http://store.spyder.brp.com/product/..._Reflector_Kit
    Good find!
  2. #27
    Active Member teadave's Avatar
    Ontario,Canada
    I purchased these a couple of years ago as my used v-35's came without the reflectors.
  3. #28
    Feb 2012
    South Jordan, UT
    Quote Originally Posted by dguisinger View Post
    The number was different completely... Neither the current RS or 2013 RS/ST versions.
    I called the store up, they said it was the 2009 model year, but that they should fit the 2012.
    Is this true? Or do the 2012 units include something to make them work on the 2009?
    Maybe its as simple as the older ones said GS and the newer ones had a new model because of new packaging and instructions saying RS?
    Anyone ever figure this out? Im trying to figure out which kit to order. Ive seen pictures of the kits that have the large turn signal stalks up high, but apparently there are some that mount the turn signals down low off of the rear fender? Just ordered the sport fender and need to make sure I dont end up with the kit that mounts on the old fender.
    Also, if i end up getting rid of the turn signals all together using the custom dynamics triple play, can i get rid of the turn signal stalks or are they necssary for the racks to function properly?
  4. #29
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by msj4848 View Post
    The Givi mounting bracket is bolted on and the turn signals are mounted to the fender. The BRP mounting bracket has quick release quarter turn hardware and the turn signal stocks are extended up.
  5. #30
    Jun 2012
    Tacoma WA
    Get the givi led turn signal kit from one of the light venders and eliminate the turn signals - cleans everything up nicely
  6. #31
    Feb 2012
    South Jordan, UT
    Are the brp signal stalks removable and/or required for the racks to function?
  7. #32
    Ontario,Canada
    Required. The rack attachment point is actually part of the signal extender stalk.
  8. #33
    Feb 2012
    South Jordan, UT
    Quote Originally Posted by ChasingWind View Post
    How would you eliminate the turn signals if the stalks are a mounting point for the racks?
    Sorry for all the questions...
  9. #34
    Mar 2014
    Waiuku, New Zealand
    Default photo
    I don't know whether this helps, but these are the mounting points for the monkey rack on my ST Ltd. There are 3 mounting points, one at the bottom of the indicator extension stalk, one in the black grille cover and the last one is mounted directly below the black grille cover where one of the rear wheel cover bolts goes.
  10. #35
    Very Active Member mastertek2000's Avatar
    Mar 2012
    E Freetown MA
    IMG_1035.jpg that's what it looks like
  11. #36
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    For my wife's bike we bought the aftermarket Givi bracket. They were much cheaper. I cut down existing turn signals to fit between the bags and the side panels they fit on. The other idea I had was to put LED light strips on each side of the rear panels to act as the turn signals. But, I then decided to cut down the signal lights and put red LED strips for extra brake lights instead.
  12. #37
    Feb 2012
    South Jordan, UT
    How did you get the bags without the brp racks? Or did you get aftermarket bags too?
  13. #38
    Nov 2012
    Ottawa, Ontario
    The BRP bags are just Givi V35 bags. We bought used bags on EBay and bought the aftermarket racks for the Spyder. You can just buy the color lids to match your Spyder if you don't just want all black bags. You can buy new bags for about $450 on EBay. The Givi racks are about $200.
    I bought my set of racks from this guy.
    http://www.ebay.com/itm/GIVI-CAN-AM-...20780b&vxp=mtr
  14. #39
    Feb 2012
    South Jordan, UT
    Thanks for you help scrive!!
  15. #40
    Jun 2012
    Central Texas USA
    The BRP rack stalks are a welded part of the rack so they would need to be cut off to remove them and bottom portion includes one of the fastening points but you could cut around that and remove the stalks but it would be a lot of work and then you would need to figure out how to attach your turn signals.
  16. #41
    Mar 2014
    Waiuku, New Zealand
    Default Saddle bags removed
    Here is a photo of my ST Ltd with the saddle bags and carriers removed, hope this gives you some idea what it would look like.
  17. #42
    Feb 2012
    South Jordan, UT
    I would really like to remove the signals and stalks altogether and use the brake lights as run/brake/turn, but it looks to be too much work...
  18. #43
    Mar 2014
    Waiuku, New Zealand
    You can get a rear light set that fits into the reflector area at the rear of the Givi bags and I'm sure I've read somewhere about a gadget that can turn your rear lights into turn signals as well, have a look on the Custom Dynamics site.
    http://www.customdynamics.com/can_am...ccessories.htm
    You could add one of their 3rd/middle brake lights and use that as you only brake light and take the wire from your indicators and wire them to your existing two brake lights, removing the brake wires first of course, hope that makes sense.
  19. #44
    May 2019
    Manhattan
    Does anyone please help I have this saddles bags on my bike and for theove if my life I can't remove the left side turnsingle mount so that I can remove the plastic to get to my battery I need to swap it out and I just can't figure this out.
    Thank you
    Juejue
  20. #45
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    Quote Originally Posted by Juejue97 View Post
    Thank you
    Juejue
    Check out this installation video.
    It’s on a ST but should give you
    a pretty good idea how they are
    mounted. Good luck
    Dennis
    https://youtu.be/aQ7lqRmP2lY
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
