Results 1 to 11 of 11
    Jun 2011
    Near Lexington, NC
    Default Rotella T5 & T6 Oil Rated JASO MA/MA2
    The T6 Synthetic 5W-40 and T5 Dino 15-40 are now rated by Shell as Jaso Ma2.
    The T5 was reported as such, with a quote from Shell, on BOBIOG forum, and I emailed Shell about the T6 and got the same reply. Shell said that they didn't change their formulation and it carried the MA rating before as thats all they tested it for. When they tested it for MA2 it passed. In effect, then, its always been MA/MA2.
    Thought it worth reporting as several folks have stated they use it and at least one said he'd been using it for a long time.
    Its up to each person to decide for themselves.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Houston
    Edit. I stand corrected. Here is the Current April 2014 technical data sheet for Rotella T6 5W40 full synthetic:
    http://www.google.com/url?sa=t&rct=j...hKjVNBD2n7XkGQ
    It does indeed now meet JASO MA2 requirements. I will likely use up the Valvoline I already have and use the Rotella going forward as I already use it in most everything else I own.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jun 2011
    Near Lexington, NC
    And the TDS for T5:
    http://www.epc.shell.com/Docs/GPCDOC...-US%29_TDS.pdf
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Inactive User
    Jul 2011
    Central VA
    Ted ...
    Have you or will you be using the T6 5W40 in your 2014 ?
    If so, please report how it does for you.
    I will likely do the first oil change at 1,000 miles.
    Thanks ...
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by SpongeBob View Post
    Ted ...
    Thanks ...
    Bob, haven't decided yet as I have enough Amsoil for two changes and a little Castrol Blend yet to use up. I did my first change, oil only, at 1500 with Castrol and plan on doing another with Amsoil and new filter before I leave for Spyderfest on 28 Apr. That will be about the time for the first service. I may let the dealer put the Amsoil in for me as I'm having some surgery done which will make it diff for me. Normally I much prefer to do my own oil changes. I'll definitely lab test the Amsoil.
    At some point, I probably will try Rotella, maybe a blend of T5 & T6. Once we get into hot wx I think T5 would be best. Theres been a couple of bikers that tested T6 on BITOG forum and it didn't hold up so well. However, diff motors and transmissions produce diff results.
    Whatever I use, I'll test it around 4-5K to check for shearing. I don't believe for a minute that these motors can go 9000 mile between changes, but hope I'm proven wrong. Cars go that long and even much longer but they don't have wet clutches and gear boxes to chew up the oil.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Motorbike Professor
    Mar 2008
    Allegan, MI
    At some point, I probably will try Rotella, maybe a blend of T5 & T6. Once we get into hot wx I think T5 would be best. Theres been a couple of bikers that tested T6 on BOBOG forum and it didn't hold up so well. However, diff motors and transmissions produce diff results.
    If I'm not mistaken, T5 is a dino oil. BRP specifies full synthetic or a synthetic blend. Use of the dino oil could jeopardize your warranty (or worse). There is more to oil than the viscosity.
    Jun 2011
    Near Lexington, NC
    Scotty, you're absolutely right, it is dino. I'm hoping Amsoil will test so well I won't want to try anything else. I've been an Amsoil Preferred Customer for many years. But I do like to tinker and if I find another brand that performs as well at half the price, then I'll go for it.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Inactive User
    Jul 2011
    Central VA
    Does Amsoil make a 5W40 synthetic ? I haven't located it yet.
    Thinks out loud
    Apr 2012
    Arrow look here
    http://www.spyderlovers.com/forums/s...071#post779071
    Jun 2011
    Near Lexington, NC
    They do make it and label it as ATV. Rated Jaso MA/MA2. Would assume its the same basic formulation as "motorcycle" oil, but personally, I'd stick with the 10-40. Just don't get cold enough in our neck of the woods to need a 5W for start up. Also, the wider the viscosity spread, the quicker it will shear. Castrol makes a 5-40 synthetic and you can order it on line if thats what you really want. Prob the same stuff that BRP sells.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Invalid Emails
    May 2012
    Locust NC
    T5 does come in a semi-synthetic
    http://www.walmart.com/search/search...7&wl4=&veh=sem
