Results 1 to 25 of 33
    Springfield, MO
    Default Breakaway floorboards work and are needed
    I got to see it in action on my 2014 RTS. I was making a right and there was traffic coming the other way but there was time to jump out there. A red car in front of me hit the gas and I did too looking at the truck that was coming. Had plenty of time but the gal in front of me changed her mind and when I turned my head there she was stopped.
    I slammed on the brakes and the floorboard broke away and I was able to get that extra amount of peddle I needed to stop the Spyder. Freaked me out but I was thankful that feature was added and now I know it is needed. Good job BRP!
    Aug 2012
    Jacksonville, NC
    Good to hear you did not wreck. Sounds like that could have ended bad.
    GOS member (Girls On Spyders)
    Jul 2010
    Grand Rapids,Michigan
    Cool
    Quote Originally Posted by Lamonster View Post
    Very glad you are alright. Your family does not need to go thru anymore motorcycle accidents. Keep that angel on your shoulders.
    Springfield, MO
    I don't think I would have gotten hurt but the Spyder would not have been happy
    Sent from my iPhone 5
    using Tapatalk
    I'm glad to hear the BRP has come up with another good safety feature for our bikes!
    And I'm double-glad to hear that it was only an. "Almost"...
    Mar 2013
    South East Wisconsin
    Default Also glad to hear your highway pegs were able to
    drop along with the floorboard, a real world product test accomplished...
    Jun 2013
    I'm really glad you (and your Spyder) were not hurt . . .
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Default Got to move the pedal up a bit
    That is the reason I added this pedal spacer when I mounted my aftermarket floorboards. You need to have some emergency pedal travel.
    BRP did it better but this works for me.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Apr 2012
    Columbus, Ohio
    Another Great reason the 2014's are fantastic machines. My dealer pointed out the breakaway floorboards on mine when I picked it up. Hope I never have to see how good they work but at least they do the job that was intended.
    Ron
    Mar 2012
    Harrison, Arkansas
    I'm so glad the drop down worked for you and thankful that you showed me the purpose of the breakaway floorboard at your BBQ last summer. Just another example of a man who has the answer to all things Spyder. Penny
    Bryant, Arkansas
    Happy that it worked for you.
    Cruzr Joe
    Here's to hoping that we never have to find out just how well they work!
    Apr 2012
    Florida
    Glad everything worked out well! Tom
    Dec 2012
    Bel Air, MD 21014
    Default Seal DLX
    I have the Seal RT SE5 DLX Floor Boards. They are delivered with a spacer that raises the break pedal. Ever since I have installed them I have wondered if I have enough brake travel distance to totally lock up or not. I have had to stop pretty quickly and all works well, but in an all out emergency situation I am not sure. Has anyone had that experience with the Seal RT SE5 DLX Floor Boards?
    Eastern North Carolina
    Now iron go out the crease in the seat
    May 2013
    Edmonton Alberta, Canada
    Glad to hear your safe Lamont and good on BRP for continuing to make a safe machine safer!!
    2014 RT-Ltd , Cognac
    Jun 2013
    Fleetwood, PA
    Quote Originally Posted by R30SHIRE View Post
    Ron
    This feature was also avalable on the 2013's. My ST Limited has it.
    Jun 2013
    NE South Carolina
    Quote Originally Posted by georam View Post
    I got the full size pedal and Seal Dlx boards. Between the 2 of them if I stand up on the pedal I have 1/4- 1/2" clearance between the pedal and board.
    Oct 2013
    Eden Prairie, MN
    Glad to hear all is well.
    Jun 2013
    north carolina
    Default seals work
    Had to apply emergency corrective action while riding my rt w sealboards not a problem. After employing my choice word program and checking the condition of my seat and shorts(due to the autonomic nervous system scare response) all was well. no worries with the sealboards and brake spacer.
    Mesa , arizona
    Default spacer
    FYI - for those that purchased the seal floorboard (long ones), before October 2013 ( I think) you will need to check out your brake pedal spacer. it needs to be 1 1/2" and thicker NOT the 7/8 that it
    came with at that time. I came close to rear ending a nice big azz truck , because my pedal slammed flushed to my board and was still rolling. done the emergency ballerina toe act to stop..it.
    I did informed seal floorboard mfg. here on SL. hopely he informed everyone...so like I said FYI to all.
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    So, what does it take to put it back on? Do you have to put a new one on? Is it 'broken' when it 'breaks away'?
    Quote Originally Posted by crazyspyder View Post
    I believe Seal now includes the brake pedal spacer with the floorboards. I have a set on both 's and the elevated brake pedals with spacers.
    Thank you for posting the beta test information on the break away floorboards.
    Very glad you got through the incident without any problems.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Cavman View Post
    Grab the front with your hand and lift. It will snap back into place ready for your next adventure!!!
