Handlebar ram ball mount
2018 F3-T
![](https://www.spyderlovers.com/forums/maps/map.png?states=ME.NH.VT.NY.PA.IN.MI.IL.WI.MN.ND.SD.NE.KS.OK.CO.WY.MT.ID.WA.OR.CA.NV.UT.AZ.NM.TX.TN.KY.OH.WV.IA.MO.AR.VA.NC.SC)
![Quote](images/misc/quote_icon.png) Originally Posted by Spydr in KS
Where did you find that ball mount?
** Loving my 5th Can-Am Spyder since 2007! **
![](signaturepics/sigpic1073_1.gif)
http://www.gpscity.com/ram-mount-m10...inch-ball.html
Coupling nut, std nut and threaded rod were from local Ace hardware. Wish I could find a black coupling nut
![Quote](images/misc/quote_icon.png) Originally Posted by spyder-dude
Try this:
http://www.rammount.com/CatalogResul...5/Default.aspx
2018 F3-T
Re: Handlebar ram ball mount
Are the bolt lengths the same for the RT?
Sent from my DROID X2 using Tapatalk 2
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
![Quote](images/misc/quote_icon.png) Originally Posted by M109Dreamer
Don't know. The ST has a deep recess in the handlebar and a long threaded bolt. I cut the threaded rod length to match the bolt length I needed. I also needed the coupling nut to mate the male threaded ram ball and threaded rod. The coupling nut gave me enough height to raise the ball up above the handlebar
Good one..!!
Ingenious nicely done i'm sure this will help allot of folks with your bar configuration. You could do two and add other electronics... !!
I tried to do this, but the coupling nut and jam nut felt like they are too wide to fit flush with the handlebar. It seemed to lack about 1/8 of an inch of meeting. I was worried that forcing it down in there might damage the handlebars. In short I gave up and ordered theses: http://www.leadermotorcycle.com/moun...-spyder-black/. I'll let you know how good a product they are when I get them installed.
![Quote](images/misc/quote_icon.png) Originally Posted by Green RSS
Grind down the coupler nut or sleeve at the bottom into a conical shape. That's what I did. http://www.spyderlovers.com/forums/s...unt-for-the-RT
The coupling nut from Ace Hardware fit no problem
Well the actual mount is a very quality piece. Unfortunately, it does not fit the ST like their webpage says. I'm waiting on a return phone call from them to see if they will do anything. They called me back and said they had just realized that their mount would not work with the 2013 ST handlebars. They said they are waiting on the local BRP dealer in Minnesota to uncrate the 2013 models so they can measure it to supply spacers and longer bolts to anyone that had bought the mount already. Sounds like they are going to take care of everybody.
Reason: Updated information
I am trying to get the two lower bolts off and replace it with screws i got with the gps mount. I read that you need a 8mm hex head to get it off. I tried it but it wont work. What did you use to get the handlebar bolt off.
![Quote](images/misc/quote_icon.png) Originally Posted by junwalla
7mm Hex head worked for me.
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
