Finally Got the Nanny to Slap Me!!!
It took some work but this is what I did on my 2012 RT:
I normally lean into turns, this is a habit. It helps keep the wheels on the ground. I normally turn onto the street that I live on, it is about a 100 degree turn, I normally take it at about 30 MPH. I lean WAY over to keep the wheels down. So today I said, "What the heck! Let's not lean." (I didn't really say "heck", but you get the idea.) So I turned. I did not lean. ...the nanny powered down and slapped me. I was watching the wheels, and it didn't look like the inside one lifted off the pavement.
So I went around again. Same speed. No lean. Same results.
So I went around again. Same speed. Lean like normal. No Nanny.
Interesting...the Nanny likes you to "lean into it." (heh).
![Quote](images/misc/quote_icon.png) Originally Posted by Dan_Ashley
You don't have to lift a wheel to get the nanny to kick in, but that may or may not do it.
The likely reason the nanny stepped in is if the steering angle does not match how fast you are turning as measured by the Yaw sensor. My 09 would do that when I was experimenting with higher front tire pressure.
![](signaturepics/sigpic7798_4.gif)
Heres some of the stuff the "nanny" watches....
left tire
right tire
rear tire
vehicle average speed
yaw rate
lateral acceleration
longitudinal acceleration
steering angle
brake pressure
LPS detection pressure (I'm not sure what this is?)
You can lift a wheel without waking nanny. You have to do it smoothly. That's all.
What us yaw? Why does it need to be sensed?
Think of yaw as "tilt". If the Spyder heels over too far in a turn it wakes up Miss Nanny. That is why leaning into the turn makes a difference. There can be other factors in conjuction with this, so you would not need to lift a wheel. To much throttle with the handlebars turned hard over, loss of traction as the rear wheel slips slightly, or a mismatch between steering torque and steering angle as the weight comes off one wheel are common additional factors or factors by themselves. Congrats on having good riding form from square one.
![Quote](images/misc/quote_icon.png) Originally Posted by NancysToy
Thanks for the explanation. I really appreciate it.
I think you mixed up yaw with roll. Side to side tilt is called Roll. Yaw is the change in direction of travel left or right.
![Quote](images/misc/quote_icon.png) Originally Posted by billybovine
Yes, I know, but I was trying to simplify it for him. The technical terms aren't always the way the average person thinks of them happening. "Tilt" seems to explain it better in terms of what the Spyder sensors actually measure. It would be roll on an aircraft.
Are you sure about that? Most cars measure yaw...as in..."Is this thing pointed in the direction it should be given steering input, throttle, and braking?". That's very important to a stability system.
![Quote](images/misc/quote_icon.png) Originally Posted by NetJunkie
This sounds very technical. I am going to go over to the university bookstore this morning and get an introductory engineering text.
So, thanks to the Nanny, and to you guys, I am off to learn something new! (That is a compliment. I like learning new things.)
All I can tell you is that the nanny does monitor tilt or roll. Ask the folks tat went into limp mode simply because they went onto the banking at Daytona on the track ride. The Spyder also compares steering angle and steering torque to determine if it is following the correct line. TI don't think BRP's terminology follows what we see elsewhere. JMHO
![Quote](images/misc/quote_icon.png) Originally Posted by Bob Denman
Nanny's just doing her job; keeping all of us off of the front pages. ![thumbup](images/smilies/thumbup.gif)
It is nice to know just what it takes to rile her up! ![Big Grin](images/smilies/biggrin.png)
Was introduced to Nanny last summer (with my wife on the back).
Nanny was not the overbearing control freak I had anticipated.
As we took a hairpin turn in an area I'm very familiar with, she gently reminded me not to get too big for my britches.
Very smooth. My wife was not even aware that Nanny had scolded me.
GOS member (Girls On Spyders)
Nanny Introduction
![Quote](images/misc/quote_icon.png) Originally Posted by FlaBound
Was introduced to Nanny last summer (with my wife on the back).....
I was also introduced to our friendly Nanny last summer .... but, in this case, she saved me (I think this is in another post, but can't find it at the moment). Briefly:
- Coming home from my trike class (about 50 mile drive)
- Had recently rained in the direction I was headed (SE) and T-storms had moved east of the highway.
- Noticed T-storm starting to collapse a few miles to my east and also noticed cars swerving badly on the highway.
- Moved into left lane -- when I reached the "swerve" point, was instantly in the right lane.
- Miss Nanny had kicked in to put a front tire back on the ground -- scared the
out of me!
Had I not been paying attention and moved left when I did, and had Nanny not kept my tires "on the road", I think I would have ended up in a ditch.
Ride safe .... Ann
__________________________________________________ _
2016 RT Limited -- "Jubilee" (as in Cherries)
Guardian Bell (gift from spyderowboy)
ISCI Dual Flag Mount – Tall Poles
Lamonster Bottle Holder and Spyder Cuff
Spyderpops Missing Belt Guard
Spyderpops Bumpskid
Spyderpops Rear Run / Brake / Turn LEDs
Spyderpops Mirror LEDs
Custom Dynamics HMT Brake
Spyderpops Keep Out The Trash (KOTT) Grills
Don't Eat Mud / mudflap
__________________________________________________ __
![](signaturepics/sigpic11148_10.gif)
They were probably going too slow on the high banked curve and the Nanny thought they were tipping over to the inside. If they had gone the correct speed they'd have been fine.
The Nanny is dynamic, meaning that she assumes a level surface and calculates everything off of that. So, she assumed that the high banked curve at Daytona was actually flat. With insufficient speed it appeared to her that the Spyder was tipping too much to the inside of the curve and she slowed the Spyder down hoping to correct the problem. But since the surface was NOT flat, her actions only made things worse (proving that the nanny is not perfect). Since she couldn't correct what she saw as a problem, she went to the Nuclear Option of Limp Mode.
On a motorcycle you lean everything into a turn to counteract centrifugal force and it is a good thing. You don't need a nanny on 2 wheels as you know pretty quickly if things are not balanced exactly right. It's called CRASHING in the technical vernacular.
On 3 wheels everything changes because you can't 'Lean' to balance against centrifugal force like you can on 2 wheels. Yes, you can lean your body and that helps. But you can't lean the machine. The nanny has no idea what you are doing with your body. There are no sensors connected to you. She only knows what the Spyder is doing, and it is leaning the wrong way into the turn. She allows a certain amount of this, but exceed her comfort zone and she will let you know.
So, too much lean in any direction and she will slow you down, which reduces the amount of centrifugal force and also reduces the lean angle (except for High Banked Turns like on race tracks), until she is happy.
There are more things that will upset your nanny than these listed. But she will definitely help you to improve your riding skills if you let her.
![](signaturepics/sigpic963_3.gif)
Lifting inside front wheel
I don't know how smooth you need to be to lift a wheel in turns, but I did manage to do it today. I just recently bought a 2011 RT and have put about 200 miles on it. Still getting used to the extra wheel (my previous ride was a '07 DL650) and I guess I was carrying too much speed into too tight of a corner (about 100 degrees). Applied throttle too early and up went the front left wheel. It was surprising but not scary. Not sure if Nanny kicked in or just rolling off the throttle saved my bacon. The best part was upon my wheels return to earth I was greeted by the sight of a white-bearded Harley rider giving me a thumbs up. Has anybody else managed to pick up the front wheels while taking a turn?
![Quote](images/misc/quote_icon.png) Originally Posted by Chupaca
Was wondering that myself. I'd hope so given how hard it'll slow you down at times.
