Results 1 to 25 of 26
Thread: tire pressure
    Invalid Emails
    Texas
    Default tire pressure
    About to go for a quick spin before it gets cold, and I have the following psi, 10 and 12 on fronts and 16 on rear. New 14's take 20 up front and 28 in the rear.
    Had the bike (new) for a total of 4 days. Have put 9 miles on the thing and is garaged on carpeted floor.
    Did the pressure really drop that low in 4 days? Not sure if the dealer even checked it when they loaded it up to sell to me.
    Jul 2013
    Vestaburg Michigan
    If cold out yes , if not then dealer didn't check .
    Very Active Member Don in E Texas's Avatar
    Feb 2009
    Gilmer, TX
    Might have been checked at the dealer --- but some gauges read different than others ie not accurate at all. Go by the book and you can't go wrong. Test tire pressure using more than one gauge to make sure you are getting the proper reading.
    don
    Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
    Now Own: 2014 Black RT-S SE6
    Find a gauge that you trust; and NEVER let it out of your sight!
    My gut tells me that the dealer missed checking the tire pressures...
    Bryant, Arkansas
    BUT 16.5 to 17 lbs in front and 28 in rear be sure fronts are very equal 20 up front might be too BOUNCY
    Cruzr Joe
    Default Maybe both..!!
    It may have been missed by dealer and the cold will have a lot to do with it. With cold weather you must check tire pressure a bit more often. Like stated find a good guage and keep it handy at all times. Glad you caught it before your ryde cause you would have had some handling difference....
    Follow the advice above. Check often and keep a good gauge handy. The only difficult tire to check is the rear. Some people experiment with + or - a pound or two--but that is your choice depending on how you like the feel of the ride.
    Jun 2010
    Las Vegas
    I just bought one of those gauges with the flexible hose on it. Really makes checking the rear tire easier.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    A lot of folks have trouble with the rear tire valve placement...
    I always thought that it was flexible enough to work just fine with the OEM gauge that BRP supplied...
    Just get the nose of the gauge started on the stem, pick up a little, and take it to the house! I always got a good, repeatable reading!
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Do the 14's still have the ± 0.25 psig between the front tires? The only way I've been able to do that is by filling both tires at the same time.
    JT
    Jun 2013
    Quote Originally Posted by jthornton View Post
    JT
    Your "dual fill" sure makes it easy . . . hook up both tires, they equalize, and add as needed, just once . . . and they are both exactly the same! You might be getting a couple orders from Tucson (or already did) as a couple friends both bought 2014 RTs and I told them about it.
    May 2013
    Redlands, Ca
    I fill my tires with water. It don't leak out hadly at all.
    Aug 2013
    Quote Originally Posted by Dan_Ashley View Post
    Bet that shakes like a big dog! Lol
    Bryant, Arkansas
    Quote Originally Posted by SNOOPY View Post
    Enough with the DOG jokes.
    (probably chewing on some unsuspecting old persons slippers)
    Cruzr joe
    Active Member 3corvettes's Avatar
    May 2010
    NW Illinois
    Looking for recommendations for a good tire gauge. Digital? Gauge?
    May 2013
    Redlands, Ca
    It only shakes when the water gets too cold.
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by Hayfield View Post
    Thanks, glad you liked it.
    JT
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by 3corvettes View Post
    I haven't seen any pressure gauges that are accurate enough to fill the tires ± 0.25 psig as the manual says. The only solution I came up with is to fill both tires at the same time.
    JT
    N. Va
    A laser alignment sort of question (and perhaps a better swaybar and stiffer front shocks).
    Once done and the wheels are set up properly, can you run more air pressure in the front tires, say from 18-20 to 22-25? The greater air pressure would help mpg.
    I wonder if the softer air pressures were is the compromise the factory adjusted because there were other issues. The softer pressures would absorb the wandering...
    Jerry
    Bryant, Arkansas
    Tire pressure at or above 20 miles an hour makes my Spyder bounce and swerve too much in highway traffic and reduces my control, if you up the pressure, ride it somewhere comfortable to see how it changes the handling. As usual my advice comes with a money back guarantee
    Cruzr Joe
    Aug 2013
    JT
    How do you do both at the same time? How do you check both at the same time?
    Aug 2013
    Cruzr Joe
    Good points.
    And how do we make a claim?
    JT
    Hi John!
    Is your dual-fill apparatus still available? How do we get one?
    (Once I get my bike anyway!)
    Feb 2013
    Poplar Bluff, MO
    Hi John!
    I have plenty of the dual fill with and without gauges. My web site is gnipsel.com.
    JT
    Feb 2013
    Poplar Bluff, MO
    I built a dual fill device to fill both tires at the same time. I found some special air chucks that will stay on the schrader valve as you adjust the pressure and have check valves so as you remove one only a tiny bit of air escapes from that tire, when you remove the other one the same tiny bit of air escapes from the second tire.
    JT
