Results 1 to 25 of 43
    May 2013
    Stanton, ca
    Default How to install the Baja Ron Sway Bar on a 2010-12 RT
    This is a little video I did on how to install the Baja Ron Sway Bar in a 2011 Spyder RT. 2010-12 is the same.
    Sorry for the shaky video as the iPhone does not have optical jitter correction! It's the only camera I could use and get under the bike to film. But this video should explain all the steps to install the bar. Enjoy! I have to say, this was far easier than what I have read! Don't be afraid to do it. Just some simple tools is all that is needed.
    Video is in 2 parts:
    Enjoy,
    Bob
    Alberta, Canada
    Thank you for your effort to film these videos and help those of us not mechanically inclined to overcome our doubts and start feeling more confident that we actually can do it ourselves. It does sound and looks quite doable. Thank you again. Great work!
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Thank you, very useful.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Great video! I know it will help a lot of people with this install.
    Thanks!
    Oct 2013
    Charlotte, NC
    This is a very good video! The only thing I still find a little bit confusing is making sure that it is centered up or "even" on both heim joints. Are those still your stock heim joints?
    May 2013
    Stanton, ca
    Quote Originally Posted by Ryblueyez View Post
    Yes those are stock. When Ron gets the metal ones ready I will probably order some.
    Bob
    Oct 2013
    Charlotte, NC
    Quote Originally Posted by finless View Post
    Bob
    Are they installed the same way? Would that be double the work? Just curious...
    May 2013
    Stanton, ca
    Two more bolts and nuts to replace the heim links. You can see them in the segment of part 2 video where I show the link gaps to the frame and aligning the bar left and right.
    Bob
    Jul 2011
    Morgantown, WV
    Excellent video! Thanks Bob!
    Default Great..!!
    how to video..this will help a lot of folks on the fence..thanks..!!
    Thinks out loud
    Apr 2012
    Cool
    Well done for a one handed install.
    Bob, ever consider radio? You certainly have the voice for it.
    May 2013
    Stanton, ca
    Quote Originally Posted by Jerbear View Post
    I have been told that before. At 54 I doubt I will be getting into radio. Would not even know where to start!
    Bob
    Invalid Emails
    Jun 2012
    Galveston, Texas
    Default BR Sway Bar Install
    Thank you Bob, video was great, helped me finalize my decision on self install.
    Will order and install.
    Thanks again!
    From this - to this
    May 2013
    Stanton, ca
    FYI, anyone living near me that wants the bar installed, I will do it for you free. I can probably do it in 30 minutes now that I have done one. So just PM me and we can go from there for a meet up.
    Bob
    Invalid Emails
    Jun 2012
    Galveston, Texas
    Default Bar sway bar
    When are you going to be in Galveston, TX? Free room & board with great views.
    Bob
    Default Installing the BajaRon Custom Performance Sway Bar - Centering Procedure
    The Pre-2013 RT install is really pretty easy. And the Pre-2013 RS/GS/RSS are even easier.
    The 2013/14 isn't really hard. It's just that raising the front of the Spyder up about 18"~20" takes a bit of ingenuity. Once it's up, the rest is not difficult.
    'Centering' the sway bar is understandably confusing to some. People naturally assume that centering has something to do with the center of the sway bar. I've even had some ask why I do not mark the center of the bar to help in this regard.
    But 'Centering' has nothing to do with the center of the sway bar. Once we get beyond this assumption things go much easier.
    I do not want to make this sound complicated or difficult, as it is very simple as long as you use the correct reference points for 'Centering'.
    Below I have tried to depict what we are attempting to achieve with this 'Centering' process. The correct reference points are the distance from the outside of the Links to the inside of the link mounting bracket. This is the only reference and has nothing to do with where the sway bar is in relation to the center of the Spyder.
    In a perfect world, the center of the Spyder and the centering of the sway bar would be one in the same. But experience has shown us that there are slight differences in location of each suspension component from Spyder to Spyder. This, coupled with the extremely tight space provided for the Sway Bar to work, means that equal clearance between the mounting brackets and links (as shown below) is most important, regardless of where this puts the sway bar in relationship to the center of the frame.
    Remember, we are talking small distances of maybe 1/8" to 3/16" difference from Spyder to Spyder.
    All of this becomes much more apparent when you do the install and you can see these component relationships for yourself.
    The top picture is what you want to avoid. The bottom picture is a correct install with equal distance (whatever that may be) between the link and the bracket.
    Oct 2013
    Charlotte, NC
    Bob
    When are you coming to Charlotte, NC? Lol
    Oct 2013
    Charlotte, NC
    What exactly would cause this, Ron? Is there anything that you would suggest using as a spacer to center the sway bar?
    May 2013
    Stanton, ca
    It's real easy to center the bar as my video shows under the Spyder and the plastic links and the spacing to the frame (link mounting brackets on the frame). You do not need to make this rocket science! I "felt" the gaps and even eye balling it is fine as my video shows. The point of doing this is so the links to not hit the brackets and break or damage them. If your off on one side my a little (small enough you cannot eye ball) I don't think that is a big deal. Again it's super easy to just eye ball them to be the same. It's really obvious once you get under the bike and look.
    Bob
    May 2013
    Stanton, ca
    Actually I might be close to there early this year! I have a friend in Ashville NC
    Bob
    Oct 2013
    Charlotte, NC
    [QUOTEless;717316]Actually I might be close to there early this year! I have a friend in Ashville NC
    Bob[/QUOTE]
    Early this year is over! LOL. It's November.... Just giving you a hard time.
    May 2013
    Stanton, ca
    A crap.... OK early in 2014
    If you really want me to do it for you I am somewhat serious about doing it when I am out there. You might enjoy the ride to Ashville and my buddy has a list and all the tools needed.
    Bob
    Alberta, Canada
    While I like your picture, Ron (I really do!), the next post demonstrates that your drawing isn't sufficient without a picture of the actual thing and those gaps depicted on it:
    After watching the video, I think I understand what you meant, but it is obvious that your drawing doesn'r explain it to those of us who did not watch the video. So, the photo would definitely help.
    I am not sure how to answer your question except to guess that you're not grasping the concept here. It is extremely simple and you may be trying too hard. There isn't anything you can do or need to do other than get the spacing between the outside of the links to the inside of the mounting bracket equal.
    Bob
    Exactly! Once you get under your Spyder and look at the components it becomes very clear.
    Quote Originally Posted by Barlock View Post
    Agreed, as the stick drawing was not designed to stand alone. Coupled with the video and looking at your own Spyder I am hoping it will clarify things somewhat.
    I know I always risk making things seem more difficult than they are when I try to simplify them....
    Alberta, Canada
    That was exactly what I meant, but I did not want to be as straightforward as you were in your response. Now you can see that the actual picture of a link with a bar end attched to it and those spaces depicted would help IMHO.
