Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 84
  1. #26
    Sep 2012
    Stetson, Maine
    Enjoying the ride, is your Spyder being worked on down to Leeds? Bruce
  2. #27
    Sidney & Rangeley Plantation Maine
    Quote Originally Posted by safecracker View Post
    No, it's at North Country. Why do you ask?
  3. #28
    Jun 2013
    Fairlawn, Virginia
    Thumbs up
    Quote Originally Posted by HuckFin View Post
    My 13 RS-S makes a shuddering sound if I take off when the engine is still cold but after that its fine. Hope its not a sign of bad things to come.
    Mine too. I've put 3500 miles on it since June and had no other issues. I was wondering if anyone else had this noise.
  4. #29
    Lakewood, NJ
    I have the same chatter plus a new stalling issue on my 2013 RT LTD. it seems to stall when hot, such as when I return to the bike after a rest stop. The chatter comes and goes. I had it in for service and the recall while up at Spyderquest. Progressive Motorsports did the work, and I trust them. However, they couldn't duplicate the problem on a 10 mile test ride, and I couldn't leave it there. As to the recall, the canister is damaged and they didn't have one, so they gave me the insulation and a part number for the canister for my local dealer's use in completing the recall. I'm glad to know that I'm not crazy, and others are experiencing these issues.
    2014 RTS , Spyderpops oversized brake pedal Cognac
  5. #30
    Sep 2012
    Stetson, Maine
    Enjoying the ryde, I was just curiuos. I forgot that you had bought them at North Country. Hope they solve your issue soon. Bruce
  6. #31
    As long as the parts come in, it'll be ready Wednesday... And I have Thursday off!
  7. #32
    May 2013
    Toledo Ohio
    Default Never Ending Problems Wake up BRP
    I have a 2013RT with 3k miles and its also starting the chatter problem in 1st and reverse This thing has been in the shop more then any other bike ive ever owned in 30+ years of riding what a Let DownAnd on top of it BRP has charged us all 25k to be a Beta Tester
  8. #33
    Quote Originally Posted by jimb57 View Post
    I should be able to pick mine up tomorrow, I'll let you know the outcome...
  9. #34
    Default I just picked up my 13 ST-L SE5
    They've replace the clutch pack and the noise is still there. The said they started the diagnosis process at the rear wheel and moved forward to the clutch. BRP was involved and they had both agreed on the clutch but it didn't fix the problem. They said they don't have any other options but to contact the BRP rep and I said do it. I still have trust in them as I believe they actually have done all they can do. The service manager told me today that he had another one in this week that they noticed did the same thing but that doesn't make it right.
  10. #35
    Sep 2012
    Stetson, Maine
    I hope they get it resolved soon. Bruce
  11. #36
    Default I'm ryding it...
    ...they'll get it back in a month or so when it's too cold to ryde!
  12. #37
    Jun 2013
    Austin TX
    Default at the dealer
    will by ride is at the dealer....
    they are looking at the problem first i was told i needed to warm it up.
    but after 15 minutes they got on the bike and they found that the bike was practically falling apart.
    after calling BRP they said the where authorized to take it apart to find the problem.
    i hope it is soon we have plans to go for a ride in the hill country next week.
  13. #38
    May 2013
    The Villages Florida
    Took my 2013 rt to the dealer for recall. Paperwork clerk starts it up puts it in reverse forgets to release emergency brake and bike stalls. I tell him to release the parking brake. He does and bike chatters in reverse also in first. I tell him it never happened before so he checkd it out with tech and bike shifts ok. So i am wondering if the parking brake does not release correctly it could cause chattering.
  14. #39
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Hope so Rick, was looking forward to meeting you next week:eek:
    Sent from my HTCONE using Tapatalk 2
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
  15. #40
    ...in the pink (Girls On Spyders)
    May 2010
    Friendswood, Texas
    just got my spyder back from the shop...they adjusted the belt by 700 newtons and re-aligned my rear tire and it appears the clatter and shaking is gone...hope this helps others
  16. #41
    Jun 2013
    Austin TX
    Default thanks
    Quote Originally Posted by flamingobabe View Post
    i will tell the tech tomorrow to look at this thread might help get my bike back.
  17. #42
    flamingobabe, do you know the current belt tension? The tech at my dealer has told me that the belt tension tolerance on the ST is much less than the older Spyders.
    Thanks for the info, I'll pass it along to my dealer.
  18. #43
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by EnjoyingTheRyde View Post
    Thats backward the 2013 all models belt tension is much higher than older models.
  19. #44
    Oops, sorry, I meant a tighter tolerance from the discussion with the tech... But it looks like the tension is much higher and the tolerance of +/- 150 N remains the same on the info below... ???
  20. #45
    Apr 2013
    Mt. Rainier
    1050 Newtons equal 236 ft. lbs using the Krikit belt tension tool. The belt on my 2013 reads 200 ft. lbs., which is a little low but I don't believe its causing the chatter sound on mine, anyway....Kind of reminds me of something loose like a muffler or tail pipe. Someday, if it ever stops raining up here I'll investigate it further.
  21. #46
    Jul 2011
    Your conversion numbers are correct but your units are not. Newtons converts to pound-force (lbf), ft. lbs is a unit of measurement of torque.
  22. #47
    Invalid Emails
    May 2013
    Northport, Alabama
    My ST-S also has this issue but it only seems to happen on a cold start, haven't really noticed it any other time. Have my second service and recall work being done on Friday and it was one of the items I was going to mention to the mechanic. I'll be watching this thread to see results from everyone else.
  23. #48
    Apr 2013
    Mt. Rainier
    Thanks much. I stand corrected.
  24. #49
    Invalid Emails
    Jul 2013
    Wayne, NJ
    Default Noises on take-off
    I've recently noticed a new noise when taking off from a start in 1st gear. It almost sounds like static noise coming through the speakers. Muted any music but sound is still there. Can't tell if it there after 1st gear because of road, engine and trans noise. Anyone else hear this?? 2013 ST-Ltd. 1400 miles
  25. #50
    May 2010
    Friendswood, Texas
    the 1050N is a new #for 2013's....thanks for posting the chart
