Results 1 to 6 of 6
    Inactive User
    Spring, texas
    Default 2013 Spyder RT Limited Issue
    Hello All,
    I really love my Spyder, I think it's a blast to drive. However, I have an issue and I am bringing it to the delaer tomorrow. The issue is heat - in particular where the seat and Front Compartment edge is got so hot it actually partially melted my garage remote and I got a slight burn in my groin area. Has anyone else had this issue and if so, what was the fix? Thanks!!!
    Inactive User
    Mar 2010
    SD
    I almost did the same thing when my '13 RT was new. I thought I would keep the remote in the handy glove box. I open the box and it is almost entirely filled with a foam insert. No problem. Remove insert and it double the storage capacity. Put my remote in and went for a ride. At the end of the ride, I opened the glove box, grabbed the remote and it was almost too hot to handle. NOW I get the idea why the insert was there instead of storage capacity! BRP knew about the heat problem and put that foam "bandage" in there to get it on the showroom floor, methinks.
    Jun 2010
    Las Vegas
    Welcome, you need to look around on the forum and you will see a lot of posts about this issue.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Inactive User
    Feb 2013
    Alabama
    That is the only issue I have with my 2013 RT. It will roast the chestnuts thats for sure.
    Inactive User
    Jun 2013
    queens ny
    Default phone
    i had my cell phone in the center compartment and it screwed my phone up and my battery from heat
    x 2.
