Got my new RT-S last night.
Question. Looking for better handling ride two up. Raise to the compressor air or lower it. Now the wife and I are both over two hundred pounds.
Congrats! Purchased an RT on Aug 23.
Look in your owners manual it will tell you the air settings for the bike. I believe on your model it is self adjusting. Good luck with your new ride!
depends on the road for me I usually do the middle setting or next down on softer. Im around 165 tho
Congrats on the new bike.
The rear suspension adjusts automatically. It is personal choice as to the setting, firm to soft.
Congrats..!!
on your new ryde..!! as to handling..if it is comfort for you're ryding partner the you can play with the suspension settings. If it is the driving aspect then you can consider BajaRons sway bar, pitbulls re-locating blocks or the elka shock absorbers...go at it a step at a time...good luck..!!
What are you trying to improve? The rear suspension affects how hard or soft the ride feels. Raise it to make it firmer. It will automatically adjust to the setting you select, and maintain that ride height. Body roll in the turns is affected by the front suspension settings, swaybar stiffness, and owner riding techniques. If you have a 2013 you cannot adjustthe front spring preload. If it is necessary, aftermarket shocks are the only answer. For earlier RT's, the spring preload can be increased. This will give a stiffer ride but less body roll. A BajaRon aftermarket swaybar can remarkably reduce body roll in the turns. The faactory bar is pretty weak. Finally, the rider can reduce body roll by leaning his/her weight into the turns. Think of it as trying to kiss the knuckles on your inside hand. I hope the answer you need somewhere in this reply.
Thanks everyone. Wife and I took the bike out for a ride on saturday. My wife hasn't riden for a number of years, but I have always been on a two wheeler one time or another with in the year. The Smile on her face made be very happy. I've been a rider for quite sometime. Living close to the Indian motorcycle plant in Springfield Mass. My Folks brought me home on the back of a 1946 Indian Chief in a A&P basket. So I've been riding sence I was 6 months old. lol.
The change from two wheel driving to 3 wheel will take sometime to get better at. All comes in time and practice.
I am just looking to get the push out of the bike in corners.
Congratulations on your new Spyder!!!
