Results 1 to 9 of 9
    GOS member (Girls On Spyders)
    Aug 2012
    Maryland
    Default Remove GloRyders for Service Appt?
    Hey all, I did search but there are a ton of posts about GloRyders. Do you all remove them before going in for service? Because the GloRyders block the lugnuts I assume you do or, does the service department remove/put them back?
    I'll ask my guys when I take it in for service but, was just curious what the norm is.
    Thanks!
    Christina
    2012 RT , Blue
    Default Don't know..!!
    but depending on the service they don't normally remove the wheels. If they do they would remove them and re-install them if they know how. If not they will ask you to but if you have doubts remove them before hand..jmo...
    If there is a chance that they'd need to pop the wheels off; I remove them.
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    As there's a risk of marring the finish on the sides of them if they try to remove the lug nuts without removing the GloRyder housing, I would recommend you remove them first if you expect the wheels to come off during service.
    If you have the glo riders, I recommend removing them prior to any service that requires the removal of the wheels. Your just asking for small parts to get lost or mislaid. Prior to installing glo riders, I had the rims changed out. Yes, they lost the plastic insert on one of the wheels. Yes, I made them replace it on their dime.
    Eastern North Carolina
    Agree. Take them off.
    Aug 2012
    Maryland
    Thanks all! I figured but, wanted to do a little sanity check first.
    2012 RT , Blue
    Bryant, Arkansas
    If you leave them on during service and they need to be removed, the dealer may charge yo more labor
    Cruzr Joe
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Phyxius View Post
    FYI, One part of the service is to check/re-torque the wheel [lug] nuts....
