BajaRons install 8/18/13
Progress report on Bajarons sway bar install.
Installed this afternoon. Took the RT out on some twisty roads and then highway. Wow what a difference. Rides like its on rails and no more swaying. Best 199 dollars ever spent.
Pictures of the old bar and the new one.
ImageUploadedByTapatalk 21376876728.008034.jpgImageUploadedByTapatalk 21376876742.587275.jpgImageUploadedByTapatalk 21376876756.320698.jpgImageUploadedByTapatalk 21376876770.670669.jpgImageUploadedByTapatalk 21376876785.054029.jpg
Installed Ron's anti-sway bar a couple of months ago and then the Heim Joint Links within the last few weeks...GREAT products!
Really improved the handling in the curves!
Wow, it took you a year to post (it's 2013)
Nice job!
Me think that 12 was a fat finger thing.
There you go...!!
And yet another satisfied customer...it will be the best handling mod you'll make...
sway bar
It's a real improvement on handling. Took my riding experience to the next level. I'm really glad I purchased one too.
2010 Full Moon Silver RS SE5
Originally Posted by shooter
Crap, just noticed the year. Should be 2013. LOL
? About last picture...is that a picture after installing the new bar? If so, is the heim link bolt tightened down? Bolt threads should protrude through the nut.
I agree, Threads should show through the nut. if not the bolts may be too short. (Good catch SpyRyd)
Cruzr Joe
The bolts are not tight yet, was still aligning the bar. Everything tight and snug now.
Okay, do you have to remove all the Tupperware to install bar?
Next Level to come
There are new products coming out on the market that will also be the next level. In testing I am impressed!!
You don't have to, I did just to per drill and per fit for a shark audio system.
How long did it take to install?
About an hour give or take.
The new RonBar is one of the best upgrades you can make.
It does, however, add nore stress to the heim link joints.
You might consider getting the RonLinks to go along with the RonBar.
I have no affiliation with the product. It's just that I'm an engineer, and therefore in touch with my inner geek.
Just a thought. I could be wrong.
IBA #47122
2020 RT Limited Asphalt Grey
