Results 1 to 25 of 38
    Jul 2013
    West virginia
    Default Help with posture on RSS please.
    Well, I've had this spyder for 500 miles so far, and what i'm still confused on is what is the best position to sit on it, Does your butt go back against the ridge on the seat, or do you sit up against the tank in a more straight up position? When you're sitting against the back of the seat you're not supposed to be..slouched? down with your body resting against your tailbone, but with your back somewhat straight, with the weight on your arms?
    I really think i need to order a riser for my spyder to give me a more upright position. Maybe I should have gotten an ST, but I love the looks of the RSS and wanted it. Can a upholstery shop turn the RSS seat into something a bit more comfortible for a longer trip? Does anyone have the pictures of someone using perfect form when riding their RSS so i can get some ideas here.
    Sorry for all the newbie questions.
    Jun 2013
    Delaware
    RSS is more of a sport riding where you're gonna be leaning more forward, riding just down the highway I'm usually back against the seat rise but back roads and turns I'm moving around the seat and leaning.
    There is a more plush seat available for them for local upholster shop may be able to soften it up some
    Dec 2008
    Syracuse, NY
    Your riding posture should be based on your body shape/type (height, weight, arm length, leg length, etc.) and your riding style for various road conditions as mentioned above. You'll know you have the right position for you when you dismount without any new aches/pains. However, pretty much any new butt pain may require something to be done to the stock seat.
    Oh yeah, I have the stock seat with the ESI 4" risers. Also, don't use a death grip on the handle bars. You'll just need to practice, practice, practice to develop your own riding style.
    Active Member Web Runner's Avatar
    May 2013
    Houston, TX
    Quote Originally Posted by Whitetail View Post
    I think Wyliec is correct about posture based on body shape/type. I bought my RS used and it already had the 4" risers. I have sat on an RS without the risers and I can tell you that having the risers makes for a more enjoyable ride, especially for road trips. Regarding the seat, mine had the stock and it was ok at first, but for long rides, it was not comfortable. I installed the BRP Comfort seat and it made the RS so much more enjoyable. I usually sit with my butt against the ridge on the seat. There are other seat choices such as Ultimate, Corbin, and Russell Day-Long to consider as well. I'm sure you will hear from other SL members that have those brands, but I sure do like the comfort seat.
    2010 Full Moon Silver RS SE5
    May 2012
    IOWA
    Get some boards that put your feet forward a bit and then some risers and you'll have a good comfortable riding position.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    The intention is for the rider to sit with his rear against the bumstop. If you must slide forward, handlebar risers or a modified seat would be of benefit, but there are no rules about where to sit on the seat. The RS (RSS) seating position is meant to be crouched, with head forward and feet back. For a different position, modifications woukld be necessary, or a different model Spyder. The ST has a more relaxed leg position and more upright torso/head, the RT has a chair-like leg position and the most upright torso. The riders height, weight, inseam, torso length, and arm length will change his/her relationship to the machine...each rider is different. As was said, the RT seat won't fit, and the RT or ST handlebars won't fit. There are aftermarket handlebar risers, aftermarket windshields, and aftermarket or custom seats than can adjust your position and riding comfort. There are also highway pegs or footboards, as well as driver's backrests if you want an even more leg forward position.
    Jul 2013
    West virginia
    I looked at the ST when i was considering buying my spyder, but did not like how it looked with the large lights on the front of it. Perfered the RSS look over it. I just ordered the BRP spacer tonight, and saw that there are a few options that are slightly cheaper than the rivco floorboards, like the mini ones from kuryakan, and theres a set from a company i can't find any info on called phoenix products. Not looking for a huge floorboard, but something a bit bigger than pegs will be nice. I always feel like i'm applying the brake when i know im not as my toe touches the brake pedal when my foot is on the peg, but i know it takes a good bit of downward travel before it starts to apply.
    May 2010
    Montville & Toms River NJ
    If you are going to do all that work of removing handlebars for a BRP spacer isn't it only 1 inch. Buy the Spyder City 3 inch spacer you will be more happy
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    Beware of the toe on the brake pedal! Although it takes pressure on the pedal to apply the brakes, it doesn't take as much to activate "Limp Mode".
    May 2012
    IOWA
    The brp spacer will barely be noticeable
    Dec 2008
    Syracuse, NY
    Don't you need peg adapters for the kuryakyn mini's? I only mention that b/c that will add to the price. If you're attaching the mini's forward from the original peg location, like I did, you'll also be paying for mounting brackets.
    Aug 2010
    Newberg, Or.
    When I had my "09 RS, I added 5" Helibar raisers. That and a 25" windshield plus my Seal Floorboards gave me a very comfortable riding position. Check out my Yellow/black RS on my website.
    Ride in comfort,
    John
    sealfloorboards.com
    May 2009
    Connecticut
    Quote Originally Posted by stormtrooper View Post
    The Spyder City 3 inch riser is good for me with the Ultimate seat that puts you about 1 inch more forward with a Definite hump on the seat.
    Be advised the actual height of the Spyder City riser is 2 3/8 inches!!!!
    The black one is 2 3/8 inch the silver is 2 inches that I sold!
    Sea Doo GTI-SE 90 Jet Ski!!
    Invalid Emails
    Sep 2012
    Clermont Florida
    Cool
    I agree the Heli bar risers are great without having to cut the bars, I also have the Cumfort seat and ISCI floor boards and the riding position is greatly improved more like the STS comfort with RSS good looks.
    Mike
    Jul 2013
    West virginia
    Quote Originally Posted by ARCTIC View Post
    Actually, the RSS i test drove was a 2013, and i didnt mind the seating position on it at all and felt it was just right, over the 2012 i purchased which lacks the 1 inch spacer, I must be one of the few people the 1 inch spacer is perfect for.
    To the poster who said about the mini boards, I thought the ones i saw came with them, But maybe they didnt. Has anyone had experience with the phoenix ones?
    Jun 2009
    Wetumpka, Alabama
    Default ISCI Adjustable Handle Bars
    Not to highjack the thread or anything, but we do offer a nice set of adjustable bars for the RS to fit most anyone. If having to lean over is an issue this could solve the problem. Let me know if I can be of help.
    Billy
    May 2010
    nh
    For me I found the use of risers on the rss to be less comfortable. It causes you to sit more upright but your knees and legs are still being bent backwards in more of a sportbike angle, which I find more comfortable when leaned over with the stock handlebars.
    however if you use risers in conjunction with floorboards that allow you to open your leg angles to a more upright position (think knees 90 degrees like a chair) it creates a more forgiving position.
    I still prefer the stock position for seriously hauling but life is full of compromises.
    also this is only my experience and your mileage is guaranteed to vary
    Apr 2009
    Mission BC Canada
    For me, at 5ft 8, I found the one inch riser and highway pegs works well, allowing sport riding and some touring. If I were doing more than 350 miles per day, I would want taller risers though, or an RT. The stock seat suits me well, but most people seem to opt for more comfort. Each individual is different. You will just have to experiment till you find your personal sweet spot, I'm afraid.
    Whitetail,
    don't apologize for any questions; unless they're ones that you didn't ask!
    This all ultimately boils down to figuring out what it takes for YOU to be comfortable on the bike; nobody in here can tell you what that'll take.
    The GS/RS models are blessed with an abundance of options as far as to getting the 'bars at the proper height for you.
    But... changing the bars will also probably make you want to change other items; windshield height and footpeg postioning come to mind!
    Do you have the BRP Comfort Seat on your bike yet? A lot of folks have mentioned that it seems to work pretty well...
    Again; the aftermarket is just screaming with options...
    Floorboards: Seal makes a great one. John got started with boards for the GE/RS models, and I've yet to hear anybody complain about them. I personally use ISCI 'Boards on my RT and have been 100% happy with them. There's a whole bunch of other high-quality choices out there as well.
    As much as this hurts ; I'd suggest making changes to the seat first, then the bars (in small incremental amounts), then the windshield, and finally the pegs or floorboard options...
    Good Luck, and Happy Hunting!
    Jul 2013
    West virginia
    So i went an adjusted the parking brake on my spyder today, now it wont roll away. Those of you who have installed spacers on your bars, did you do it yourself, or did you have the dealer do it? Ive got the spacer instructions, and it doesn't seem that Hard, I just need a Tq Wrench to do it with.
    Aug 2013
    ALBERTA, CANADA
    I bought the Phoenix Boards, one of the first things I up graded. They definatey helped now can put heels on the front rather than middle of foot on OEM peg. Had to get thier shifter also was little too close to board, cant seem to upload pics will try again...Doug
    If you don't have a torque wrench; just pay close attention to how much effort it took to get it off... just put it back rogether with about the same amount!
    Aug 2013
    ALBERTA, CANADA
    Think from my IPHONE can upload a pic of my Phoenix pieces...Doug
    What most posters said about riding position. I ended up putting a Corbin seat and backrest on my GS. The seat, in conjunction with the 3" risers, worked well for me as far as sitting position. I am 5' 5" tall.
    Don't remember if I mentioned it here, but recently rented a Spyder RS in stock mode. It was very tough for me to ride since I am now used to the sitting position on an RT.
    Here is a fully farkled GS--1 year before they introduced the RT's.
    Jun 2012
    Cumberland Cove - Monterey, TN
    Quote Originally Posted by CANUCK SPYDER View Post
    That is a very nice set up and a great choice for the RS.
    Carl
