Results 1 to 25 of 30
    Springfield, MO
    Default 2013 Stabilizer Bar Link Rods (FYI)
    If you have a 2013 Spyder and you want to check your links to see if they are part of the bad batch here's the info.
    Jun 2010
    Las Vegas
    Thanks. Is this a service bulletin?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Good to know..!!
    thanks for keeping us ahead of the curve...
    Jul 2011
    Mitchell, Ontario, Canada
    Default Not agian.
    Thanks for the info Lamont.
    Now I have to lay on the concrete floor and look at those links again. I just did that yesterday.
    Apr 2013
    South Carolina and Florida
    I just received from BRP a link with CCV1 3, which I had ordered so that I would have a spare for my 2013 RTS SE5. Based upon your information, this would not need to be replaced. However, both of the swivels were stuck so hard that I could not move them with my hand. I had to use a screw driver to break them loose. After oiling them I can now move them with my hand. Did BRP indicate what was wrong with the earlier links? Am I wrong in thinking they should move freely with my hand?
    Very Active Member Mike,P's Avatar
    Sep 2011
    Wales , Michigan
    Cool
    Thx Lamont
    Quote Originally Posted by Huddleston View Post
    Not speaking for Lamont, but the OEM links have very tight Heim joints. Probably because they are a composite plastic and they need to be tighter than typical metal to metal or metal to nylon Heim joints. If you can move them reasonably easily with a bolt or screwdriver through the hole I wouldn't worry about it.
    However, over time these joints can get pretty loose (could be wear, could be fatigue of the composite plastic). I pulled the OEM links off my 2008 GS (32,000+ miles) and the balls were loose to the point that there may be some slop in the ball and socket when under stress.
    Apr 2013
    Thanks for the info.
    Jun 2012
    Roseland FL.
    THANKS SIR.
    Invalid Emails
    Ormond Beach FL
    Default La monster comes through again
    See Lamont relieved everyone's mind again. I feel good about my SWAG being on target too. I got lucky!
    Now we can sit back and wonder what will the next crisis be? When will it strike?
    Invalid Emails
    May 2013
    Butler County, Western PA
    Quote Originally Posted by Lamonster View Post
    Is there an easy way to check these?
    Jun 2013
    NE South Carolina
    Just curious where did you get this info from Lamont before I school my service dept (again).
    Invalid Emails
    May 2013
    Default need help
    Quote Originally Posted by Magdave View Post
    Can someone please tell me how to check this? I do not know what panels would need to come off to see this part. Thank you! Jill
    Jun 2012
    Hampton, Virginia
    Post
    Quote Originally Posted by 03hdjill View Post
    No panels need to be removed but you will need to raise your Spyder's front end and crawl under it to see the links. Search for other posts on this subject and there should be some posts with pictures that show the location of the sway bar links.
    Sure, just look at your links. They can be seen from under the Spyder. Find the sway bar end and the link will be bolted to it (hopefully ). The sway bar assembly is located between the front wheels.
    Your sway bar will be black, not brown like this one. (Where did he get this sway bar anyway? ) But I digress.
    Once you find the link then you may need a flashlight to get a good look at the black on black lettering. Worse case senerio is that you'll have to remove the link to look at it. This is pretty easily done but you should be able to see the numbers without removing the links.
    If you don't have a 2013 then you don't have a problem (unless you've replaced a link recently).
    From the big boys at BRP. You can take this info to the bank....
    Jun 2013
    NE South Carolina
    Thanks Ron had to tell them the p0127,p0217 stories since BRP hasn't put that info out to the dealers and I just wanted to make sure. It is what I thought though.
    Jun 2012
    Cumberland Cove - Monterey, TN
    Yet another piece of information to in our Spyder arsenal.
    Carl
    GOS Founding Member (Girls On Spyders)
    Apr 2011
    Arkansas
    Thanks! Posted this on Girls on Spyders (with clear instructions not to ask me any questions, but come straight here for the answers). I love it when we can provide valuable, up-to-the-minute information for our riders!
    Jun 2013
    NE South Carolina
    This is a recall on some models according to BRP the bulletin number is 2013-06 I just talked with them and mine is included . They say it is stabilizer link inspection. Don't know if that means just inspect or replace but I assume the above information will be the determining factor.
    Just checked the one I could see "4" with no white dot dam replace.....
    Banged Up Member
    Dec 2009
    Sanford, Florida
    Had mine replaced today. Took about 15 minutes and no charge. I was on my way in no time.
    Chris PS: Edit: [It wouldn't be a bad idea to call your service department first and making sure they have the part before running down there to change out.]
    PSS: Your dealer will know your Vin# and can find out via their computer whether you need this change or not.
    ...in the pink (Girls On Spyders)
    May 2010
    Friendswood, Texas
    My links are different...one is a 4 with no orange dot...replace and the other is a 2 with no orange dot...do not replace.....I'll replace both thru Baja Ron resize1.jpg resize2.jpg
    Bryant, Arkansas
    Oh no, now i am in trouble again ........................... one of mine had a 3 and one had a 2, i replaced both of them with the metal ones from Baja Ron ................. (the note says do not replace) . How much trouble am I in?????
    Cruzr Joe
    May 2010
    Friendswood, Texas
    Cruzr Joe
    Bryant, Arkansas
    Quote Originally Posted by flamingobabe View Post
    OUCH, that happened to me when i took the tag off the pillow.
    Cruzr Joe
