RT-S PE#0412
Lights
I have the same Spyder as you do with all the same lights on it and it just sounds like the mechanic just pulled a couple of wires off
Most likely a connection issue.
RT-S PE#0412
I find my fender running lights frequently vibrate out of their socket. If the other lights are getting some power from the same circuit, it's possible the disconnected bulb is the culprit, as I've seen it cause my channel lights to go out and flicker. Pop off your running lights and make sure the bulb is still plugged in.
Very simple to do. Grab a small flat head screwdriver, slide it under the front section of the light where the little notch is and lift up/forward gently. The idea is to slide the enclosure backwards while lifting the front section up. Then the top comes off the wiring harness with a simple twist.
formerly pman2011
I agree that it's a loose connection, the connection should be made under the fender tip light using posi-tap connectors. I would check there and make sure nothing is loose.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
