Seal FloorBoards
I purchased some Seal FloorBoards the other day for my 2011 Spyder RT-S. I was pleasantly surprised at how heavy and sturdy they were when I opened the box they were delivered in. All the components were there, as well as detailed installation instructions. It didn't take me long to install them, and they are just want I wanted. Looking forward to putting many comfortable miles on "Trinity" know that I have these Seal FloorBoards.
![Quote](images/misc/quote_icon.png) Originally Posted by redbirdz66
Always a pleasure to hear from another satisfied customer . It was a pleasure working with you. Now, get out there and.......
Ride in comfort,
John
Seal Floorboards
Lots of compliments on my seal floorboards. They let me move my feet all around. Love Them!!
![Quote](images/misc/quote_icon.png) Originally Posted by Bob Denman
John,
Who gets more Postive Press in here: you; or Ron?
![2thumbs](images/smilies/a18.gif)
I think it's about equal. Two of the absolute best mods.
Love my seals pups great mod!
Hey Bob,
You are so right. We do have great venders. However, good press is the RESULT of paying attention and great customer service. There's no substitute for it. Let's not forget Reggy when we think of positive press.
Ride in comfort,
John
Seal Floorboards
![Quote](images/misc/quote_icon.png) Originally Posted by Ga Blue Knight
Seal Pups ROCK.
Cruzr joe
![Quote](images/misc/quote_icon.png) Originally Posted by Cruzr Joe
![agree](images/smilies/agree.gif) Seal Pups ROCK.
Cruzr joe
Maybe you need a new sway bar, Just kidding!
![Quote](images/misc/quote_icon.png) Originally Posted by FlaBound
Everytime I mention how great the seal floorboards are to the boss (my wife), she tells me "I still don't have your list".
(I have a birthday coming up in a couple months) ![yes!](images/smilies/pepper2.gif) ![yes!](images/smilies/pepper2.gif) ![yes!](images/smilies/pepper2.gif)
Ok, so what's the hold-up? It's time to......
Ride in comfort,
John
Seal Floorboards
![Quote](images/misc/quote_icon.png) Originally Posted by sealfloorboards
Ride in comfort,
John
Seal Floorboards
I'm so tempted to give you her cell#
But...better late than never.
I've learned looking forward to things, is half the fun.
Good Lord willing,and the creek don't rise
We'll be in touch
I agree.....think my dealer does too!!
After playing with another brand , I got full length Seal Floorboards for my RT Limited. The comfort was great & when I combined this with a new comfort seat I was in heaven.
Just got my Spyder back from the dealer for routine maintenance & he couldn't have been more impressed. I would be surprised if he starts carrying them in his inventory.
These are the best investment I've made since buying my Ryde.
Background
I have been riding motorcycle since 1976 all 2 wheelers until the Spyder RT-S SE5 In Dec 2010
Due to a disability I have never been able to use my left leg without the aid of a calliper I was always concerned about how to keep my foot on the LHS Footrest and modified the LHS Footrest with a stop to ensure my left leg would not slide off
I did modify the Spyders LHS Footrest in the same way (See Photo in Album Gallery)
Many had posted about floorboards and this looked like they would my give me more room
I purchased a set of Front and Rear floorboards from Inspector Gadget and they were excellent but I just felt I needed a little more width – Just over the standard width of the OEM Footrests
Having seen photos of the Seal Floorboards and noticed they were about 10” wide decided to order a set from John
I contacted John and he was able to post them to the UK
Within 3 weeks they arrived and I fitted them
I made some changes to the fittings as I like Stainless steel nuts, bolts , & washer etc
I advised John of the Changes just for his info
John
Ref the Seal Floorboards
Fitted them yesterday - Very easy to do and follow your instructions
I did make some changes to the fittings as I like to use Stainless Steel Nuts, Bolts etc
This is what I used on each side
For the Front Fitting
For the main footrest fixture - Some foam rubber under the floorboard - I used 2 x M6 45mm Stainless Steel Hexagon Flanged bolts + S/S Washer for the top and under the Seal Floorboard - S/S Washers under the weights and S/S nylock nuts & Dome Nuts to cover the threads and prevent dirt getting in
For the Rear fitting I used
1 x M8 40mm Flanged S/S Bolt 3 S/S Washers 1 rubber washer 1 Nyloc nut and a S/S Dome nut and foam rubber on the L shaped bracket under the Seal Floorboards
I Put the M8 Bolts + 1 S/S Washer in from the outside so the head will show and this goes against the L Shaped bracket - after the bracket goes the rubber washer then a S/S washer this goes against the rear passenger footrest on the other side goes another S/S Washer the Nyloc nut and the S/S Dome nut to cover the threads as this bolt is on the inside and this will prevent an dirt getting in
To attach the rear Seal Floorboard I used 1 x M6 30mm Flanged S/S Bolt & S/S Penny washer – Foam Rubber under the Seal Floorboard on top of the L shaped bracket and underneath the L Shaped bracket a Rubber washer and a Large diameter S/S Washer secured by a Nyloc nut and again S/S Dome nut to cover the bolt threads to stop any dirt getting in
Notes
Foam Rubber strip used Black - 50mm wide and 3mm Thick
This is a closed cell self adhesive Strip – Ideal for isolating from vibration
It is the closed cell type foam rubber which will not absorb water,
I kept the Rear Inspector Gadget footrest as they are a much better match than the OEM rear footrest inserts and are of the same quality as the Seal Floorboards
View the pictures with reference to the above in my Album gallery
See - http://www.spyderlovers.com/forums/a...p?albumid=2903
I have only been out on a couple of trips now and found the Seal Floorboards are excellent and agree with all the positive comments posted on them by other members these will be a great asset when on long trips as they allow me to move my feet around and they have forward footrest built in
I have not had to modify them with reference to my left leg disability as with the extra width my foot remains firmly planted on the Seal Floorboard
I was so pleased John was able to supply them to me in the UK
If I am asked for info on them I will advise them of his website and will recommend they get in contact with him
I can't thank John enough for the excellent Product & Service you provided me with
Very happy to recommend the Seal Floorboards to all
Thanks John
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
![](signaturepics/sigpic6047_5.gif)
Looking good Eddie, I checked out your pics and must say you do a great job of providing very viewable pics. I was wondering though what the reasoning behind the foam is? It seems to me that it would possibly allow the screws and Seal Floorboards to move possibly causing extra wear on the fittings.
![Quote](images/misc/quote_icon.png) Originally Posted by eddieshep999
Background
John
Notes
Thanks John
Thanks Eddie,
You did a couple of very simple changes and came up with the perfect set-up for you. Your kind of thinking is exactly what prompted me to design the Seal Floorboard in the first place.
I loved the Spyder, but needed to improve it to fit my needs in order to......
Ride in comfort,
John
Seal Floorboards
![Quote](images/misc/quote_icon.png) Originally Posted by RT Driver
Vickie, I just ordered them and look forward to installing them. Since you are so close we should get together for a ride!
Madonna
West Springfield
2018 RT Limited Champagne Dark
![Quote](images/misc/quote_icon.png) Originally Posted by donec
I decided to use the Foam Rubber for a couple of reasons
The Seal Floorboards will sit flat on the L shaped bracket but you will find the OEM Footrests are at a very slight angle so the Seal Floorboard will not sit flat on them the Foam Rubber fills any gap and does not allow any water to sit between the OEM Footrest and the Seal Floorboard
Foam Rubber will also take up vibration as this will stop any metal to metal contact between the Seal Floorboards and both the bracket and OEM Footrest
The use of Nyloc nuts on all bolts will ensure they remain tight and I used a lager M8 bolt on the rear fitting that goes through the rear passenger footrest hanger - No modification needed as John has drilled the hole in the bracket to allow the M8 Bolt through although it may require you just to screw it in due to the thickness of the paint used on the bracket
Hope this helps
Eddie Sheppard
Poole Dorset UK
Seal Floorboards
I got to tell you that my Seals for my RT are terrific, mine are the full boards, I noticed in the previous posts that no one mentioned anything about water, these things actually protect you from water splashing up because they are solid and block out any rain from getting to your legs, after getting caught riding in heavy rain before we could safley stop to dawn rainwear my lower legs were completely dry, the others in the group riding Harley's and Star Stratoliners were not so lucky, they were looking at my dry legs with envy, shoulda bought a Spyder and not a Hog!
Dave
Got Em!
Brought the spyder up last night for a quick belt adjustment in between services. When I picked it up.. Seal Floor Boards were installed! My darling bride ordered them, and somehow sneaked them to the dealer, and voila. I LOVE them. Now my feet aren't always behind my knees, and I can STRETCH. Left knee was beginning to ache a bit, and I was dreading the cold blast it would get with winter riding. Plus they look cool.
Does this company still exist?
