My Wolo Bad Boy AirHorn Install
I just installed my air horn but also wanted to keep the OEM horn since I tinkered with it and was able to rotate it by adjusting the slack in its wiring and using T splicers to tap into their power.
I used feed back from previous installers and mounted the airhorn facing left right behind the forward fuse box.
I also mounted the relay on the piece of plastic hanging from the center console. I placed my negative lead to the same location I grounded the 2 Brothers Juice Box and sent the positive to the battery (using excess wiring from the horn wires).
I gave 2 short bursts to test it, and it scared the hell out of me. Haha its definitly louder! I could actually hear it echo.
air horn
what plastic body panels did you remove to install the horn for a location ? or was it installed by the frunk fuse box ? a easy place maybe
Nicely done..!!
we dumped the oem horn and went with the bolo solo...!!
20130320_102129.jpg it is loud that being the point..honk on..!!
It's definitely a tremendous difference from the stock one. Great job!
![Quote](images/misc/quote_icon.png) Originally Posted by joet82
I just installed my air horn...
Is that screw holding the relay going to come loose? Just wondering... if I am seeing it correctly.
Nice job. That project is on my list... someday... whenever I get motivated enough.
as your picture looks like to me you put it under the front right side so you must have removed the body panel to get their ?? is their a way to mount it by the frunk some place I,am just looking for a easy way to mount it as I don't like to remove the panels as they give me fits to stay on and not shake otherwise ?? oh where is the horn located on the RT bike anyway front right or left or in between ?thanks Rich
![Quote](images/misc/quote_icon.png) Originally Posted by Illinois Boy
Nice job. That project is on my list... someday... whenever I get motivated enough. ![thumbup](images/smilies/thumbup.gif)
It hasn't yet.
![Quote](images/misc/quote_icon.png) Originally Posted by spyderpoop
The stock horn is located in the same place as on the RS. I'm not sure if the RT location for the bad boy is the same spot as the piece I used is a support for a body panel. And yes, I had every body panel off as I also replaced the airbox that day as well. I personally don't have issues with them besides trying to keep track of the screws.
