Insert a flex tube of some sort in the space between the cat converter and the gas tank. Do not allow it to touch. Vent it to an exhaust fan out the back to create negative pressure. Air should enter around the handlebar vent on the ST. Problem solved. Would someone be willing to try this? Maybe you could use a 1 1/4" radiator hose as a test. Does anyone have a photo of this area?
recent thread had two turbo fans installed in the fog light holes venting to the cylinder heads claiming no more heat problems..yesterday or before. Have ordered some and will try it out and let everyone know..!!
Dog... (Or is it "Dawg" now? )
This just looks like a project that you'll have to tackle on your OWN ST!
Tell your Best-Half, that the folks on SpyderLovers are counting on you to come through with a workable design to save folks from catching on fire in traffic...
That's right.. Counting on you
Given that I am Spyderless, would someone consider looking into this? Some closeups of a naked ST would be good. Perhaps collectively we can solve this.
I read that thread and it did look very interesting. Would you mind sharing what fans you ordered and from where? I am thinking of doing the same thing on my RS.
this is what i found on ebay under turbo fans,some diferent ones they work of the wind turning them so they wont help when stoped in less you are heded in to the wind.
I tell you that if you install the Titanium Heat wrap with a temperature sustainability of up too 2400 degrees, this will reduce the problems of sitting on a BBQ. I just completed mine and it took 64" 6" of material, which you install dry, and used both stainless steel hose clamps and stainless steel tie wraps to hold in place. Problem solved. It took me about four hours to complete after the Tupperware was removed, and I dropped the "y" pipe to wrap it. I would not say easy pezzy, but what a difference it makes.
Is that a cooling fan for a refrigerator in a RV? If it is, that is not going to provide any real cooling on a Spyder. They are used to create only a small updraft to the cooling fins on the back of the refer. They are meant to be very quiet, low power draw and create only a draft. I only ask this because that pic looks exactly like the fans I installed on my refer in my toyhauler.
Sent from the corner of walk and don't walk....
Nah!. I just used that as an example. I just threw this out as an idea that needs to be looked at to see if its able to be done. Some naked pictures of an ST would be nice, especially the area around the cat converter and the bottom of the fuel tank. I just thought that air flow might be achieved under the skin from the handlebar vent to the back of the spyder by drawing it out with a 12volt exhaust fan located in the space near the rear tire. Without actually seeing if there is room I'm only brainstorming. I want to think there is a small space between where the pipe bend is and the bottom of the fuel tank. By using a flexible high temperature hose such as a radiator hose connected to a mini high speed 12volt fan, you might be able to get reasonable air flow by creating some vacuum under the skin. Again I'm only brainstorming. Would someone with an ST want to take some pictures to see if this is do-able?
Someone was talking about putting fans in the fog light holes. I missed that link. Can someone post it again?
Why not order an ST radiator fan and see where you can squeeze that in? It's powerful and made to survive on a bike... I'd be surprised if most fans would survive on the road for long.
But I'm not really sure how much it'll change things either. If 85mph of wind against the front doesn't move enough air, I don't know how a fan will.
once again I will say that for what we pay for these and the profit they must make BRP should spend a few $ up front and ceramic coat the pipes and cat at the factory how much can it cost at that point in production THEY SHOULD AT LEAST SHOW AN EFFORT
Just wondered if you installed the turbo fans yet? Where did you order them from and what size?
Didn't work for us - we even siliconed the wrap and added heat deflection sheets on the panels. Glad it worked for you.
Do you know where I could purchase an ST Radiator Fan?
it would be cheaper to go on ebay and buy a small car fan and try and fit it in some of those small fans are as small or smaller than the spyder fans and will prouble work better .
If your thinking of using the ST Radiator Fan as an auxilary fan to help disipate heat from the exhaust system, I fear it may lead to disaster. The shear size of the fan leads to all kinds of issues with a viable spot to install it, and second, its a plastic/polymer/??? fan made to withstand radiator temps. and while I'm far from being technically inclined in manners such as these, I'd fear the fan melting and possibly causing a fire or worse with the extreme heat it would be subjected to in dealing with the exhaust system. Maybe someone that is familiar with these parts and situations could chime in and offer some better guidance. I'd just hate to see something bad happen from unintended consequences
Finding it difficult to understand why we should have to come up with designs or remedies to problems that shoud be resolved and payed for by the manufacture(BRP). After paying the amount of $$$ for the purchase of a new Spyder, and then having to pay more because there is a defect is "STUPIT". You would never think of having to do something like that with a brand new car, or other product. The only items a consumer should have to pay for are accessories, enhanced performance and the normal routing service
Any chance you would be willing to post a step-by-step for us novices? I would love to do this, but I've never tried to take all the Tupperware off Thanks!!
Can't speak for everyone, but I think the simple answer is=Cause we want to ryde
I totally agree with you
But, with that said, the heat issue doesn't effect ALL Spyders the same way, & if we all had to park our rydes and wait for BRP to come up with a viable fix, then wait for our dealers to get said fix implemented on all the effected Spyders, well, there'd be allot of folks paying good money for a sweet looking yard/garage ornament while they waited for their time in the shop to get the repair done. So, I think that may be one of the main reasons why many of those that are creative seek ways to correct an issue, to maybe make their rydes more suitable, tho temporary it may be, until BRP can come up with a fix (if they ever can) to the problem. That's just my opinion, and as I 1st stated, we shouldn't have to do anything like this for ourselves, but I know I'd rather try and be ryding than not try and watch my ryde sit and wait...... for who knows how long
This has been a problem for six years, they will not fix it until we stop buying their product,
RT and Happy. I have very minimal heat issues on my 2010 RT. I expect some heat because it has to go somewhere, just as my motorcycles do. They produce heat and you feel it when not moving down the highway. From all the complaints it must be an issue with the RS and ST's. I just wonder that at slow speed such as 10 mph or below, could the cooling fan on the radiator be reversed and blow back through the front to at least take the hot air away from the feet? At speed the fan doesn't run anyway. Might be worth a try.
What kind of Turbo fans and where to I get them? Also, not a wrench - how do you "vent to the cylinder head?
