Vary the RPMs during break-in..but by how much?
I'm picking up my new RS-S tomorrow, just in time to leave with a couple of other riders on a 600-700 mile loop through central KS. Unfortunately, my first day's ride will be mostly Interstate. I know the recommendation is to avoid steady-RPM cruising during break-in, so how much do I need to vary the engine speed along the way, and how frequently should I try run it through the whole rev range? I want to break it in properly, but I also don't want to drive my riding companions bonkers.
I've broken in plenty of motorcycles before without any issues, but always started with a couple hundred miles of short, around-town trips before taking a longer tour on the superslab.
Any advice is appreciated.
2013 RS-S SM5 [His] • 2021 RT Base [Hers] • 1977 Bultaco custom roadster • 1974 Harley-Davidson/Aermacchi 350 SS
Companion riding on a longer trip and break in miles simply don't go hand in hand. If you want to break it in properly, then prepare to disappoint them. jmo
You know the right way- Short-Varied-Some cool downs-Etc! The choice is entirely yours?
Sea Doo GTI-SE 90 Jet Ski!!
A group ride wont hurt at all. Vary the RPM's when it's convenient and move between 4th and 5th gears to help. I think engines are built really well for the most part, and require very little break-in. Change your oil and filter(s) at 600, and have fun.
I "broke in" my 2008 and the 2010 just like I ride them. No issues. 43K when I traded the 2008 and now 38K on the 2010.
2008 GS SE5 in 2008
2010 RT SM5 in 2011
Breaking in
I feel your pain. I am a Lone Ranger rider most of the time. I know if it were me riding with you all I would need is a few words as to your planned on riding style. Like I am going to run between 55/65 and an occasional run up 67.8 MPH.
speed
the day I got my spyder I drove almost 100 miles from the dealer to home and the dealer never said a word about breakin varying speeds but I would think since its a high rpm engine that the important part is not to lug it until it has some miles on it but who really knows as I seen some new bike go on 500 mile trips right from the start ?
![Quote](images/misc/quote_icon.png) Originally Posted by Dudley
EXACTLY! ride it aggressively and go. I wouldn't skip on that ride. Just shift through the gears occasionally and play with it while cruising down the interstate
Many schools of thought when it comes to break in.
Obviously, there's the "by the book" way. I'm sure that way will work just fine.
That said, there's also the "aggressive" break in espoused by some. Best description online can be found here: http://www.mototuneusa.com/break_in_secrets.htm
With my Spyder, I followed those recommendations, and have had no issues since then. Of course, I've only got 14,000 miles on my bike, so who knows if I doomed it at 40,000 miles, and I just don't know it yet.
But so far, so good.
I have "broken in" many new bikes and cars. I ride them like I just stole them. I have NEVER had even a slight problem. I even took a Triumph 2300 Rocket 3 and installed a Supercharger within 100 Miles of it being new. Rode it like i stole it also. My opinion::::: Break it in like you will ride it..... Engines are on the money now. Not like it was "back in the day"
![Quote](images/misc/quote_icon.png) Originally Posted by Illinois Boy
I'll stir-up the fire here a bit and post this link... which typically starts the debate-fires going...
http://mototuneusa.com/break_in_secrets.htm
This what I do to break-in engines, and it works from my experience.
Others can do what they want, how they want (which is why I do not buy used vehicles).
Before anyone starts to debate... please take the time to read the material first (despite it being a crappy web design setup).
EDIT: Didn't realize Daveinva just posted this.
I agree with the doubly posted motoman method 10,000,000%
![Quote](images/misc/quote_icon.png) Originally Posted by rabtech
The caveat is to let the motor warm up to operating temperature FIRST and only right before you're going to ride it properly. NEVER, NEVER keep starting it when it's new to show your buddies how it sounds or whatever......
![Quote](images/misc/quote_icon.png) Originally Posted by ARCTIC
Yes, this is soooooo important. It is a rule I live by. You can ride it like you stole it. However, Get some oil to the top of the engine and get a little heat in it. DONT start it and race it up. Engines are built to have a load on them . Just racing them up is asking for a problem.... Its ok to give them a slight rap every once in a while at a red light but dont make a habit of it...
MotoMan engine break in the best way
After engine is warmed up, the first 20-50 miles should be on the gas up to about 6,000 rpm, then let engine slow you down; several times. While on freeway, you can downshift to about 6,000 rpm (speeding up), then allow engine to slow you down, (without getting run over). Just vary rpm up & down during your freeway ride & it should be good! Congrats on new RSS Spyder . All my bikes & Spyders were broke in the MotoMan way; & all do not use oil, and seem to have plenty of torque/power. You are a seasoned rider so no problem with engine break in. I put 2oz of Lucas upper cylinder lube in gas tank before 1st fill up & 1 oz every tank after that.
Your 2013 Spyder comes with upper cylinder lube in gas tank, as per Len at Pitbull Powersports Springfield, Mo.
Good luck. Have a fun ride!! Jim
Engine BREAK~IN
Many of our family members have responded to you with great and accurate ways of breaking in your engine.
More importantly is to vary the engine RPM every few minutes!
ALSO BE SURE TO USE COMPRESSION TO SLOW YOUR ROADSTER.
SEATING THE RINGS
It is equally important when breaking in your engine to vary the RPM both in acceleration and compression! After all what you are doing is assuring that the rings work in both directions! The ring movement (however small it is in the ring lands of the piston) have to take the force of hard acceleration and compression.
Look at some of the race engines; they run only about 20 minutes between 1,500 to 2,500 RPM with a few short blasts of 5K or 6K for a few minutes before heading for the track. Once on the track it is hard at it going down the straights and then fast down shifts coming into the corners (compression)
In all this the bearing inserts are also getting seated in during the initial start up / break in period. About 20 minutes.
A question to ask is, How much running time does the engine have on it before it is crated and shipped out from the factory and the dealer prep time? I think the initial break~in (20 minutes give or take) has been completed by the time we take delivery.
This is not to say you will be abusing your Roadster, it is only suggesting that you give it a reasonable workout and vary the RPM from low to high 3,500 to 7,000 what ever you feel comfortable with.
RYDE ON and enjoy your new ROADSTER
Reason: added comment
Thanks for the advise. We talked it over and we're going to make all of the trip on two-lane state roads except for one 60-mile stretch of interstate midway.
![Quote](images/misc/quote_icon.png) Originally Posted by Jerbear
Excellent advice.
Tags for this Thread
