Results 1 to 18 of 18
Thread: Reserve
    Very Active Member Mike,P's Avatar
    Sep 2011
    Wales , Michigan
    Cool Reserve
    Anyone know what the reserve is when the light comes on ????
    Motorbike Professor
    Mar 2008
    Allegan, MI
    About a gallon and a half.
    Invalid Emails
    Ormond Beach FL
    Default Reserve
    My reserve when the gas pump icon comes on is1.5 to 2 gallons depending on if I am going up hill or not. We do not have any serious hills around here. Scotty would agree if you figure on the average mileage reported by most 125 miles is a good fill timep
    When that light comes on; start getting serious about finding a pump...
    Jun 2012
    Fairmont, Minnesota
    My gas light comes on at about 140 to 142 miles. It will then take 4.5 gallons to fill it. In theory, there is 2.1 gallons left in the tank. I have not tried to prove that but I am sure another 25 0r 30 miles would not be a problem.
    Oct 2011
    Jacksonville,Ar
    I would be careful how far you go. The mileage on my RT depends on how had I get on it. It very between 124 to 140 miles.
    15 rt , yes Black
    May 2012
    sussex, nj and tug hill, ny (west turin)
    don't multiple that 1.5 gallons times the number of miles you get per gallon and figure you can go that far. you never get all the fuel out of a spyder tank whether it's an rt or rs!
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by rcturner View Post
    Your theory falls a part when you realize the Spyders tank is 6 gal, Not 6.6 gal....
    No matter what the book says....
    my tops was 180 miles and 5.8 gallons. I usually fill right around 125-150 depending on where I am at the time.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    There are not 2.1 gallons left in the tank. Although the tank capacity is listed as 6.6 gallons, part of that is necessary head space for venting and expansion. The usable capacity is only 6.0 gallons. When the light comes on, there is usually 1.4 to 1.5 gallons left. A fill just when the light comes on will only take about 4.5 gallons, unless you fill too fast or too far and push gas over to the emissions canister. If you count on 2.1 gallons being left when the light comes on, chances are you are going to hoof it one of these days.
    Invalid Emails
    Oct 2011
    Binghamton NY
    Default Find the fuel stop
    I went by the 25 mile thing one time and did not make it to a fuel stop, But one other time riding in Texas three sisters and was getting heart burn trying to make it to the only gas station for miles and miles. That time I made it
    Senior MOMENTS Member
    Sep 2012
    Salem, Oregon! BUDDAH'S Country
    Default Fuel Light
    When that light comes on; start getting serious about finding a pump that has gas you can get out if it!! Or you best carry a gallon or so with you (on longer trips).
    Jul 2011
    Midway, Ky
    Default Re: Reserve
    The other factorv is "how long has the light been on before you noticed it".
    Gene
    Sent from my SPH-L710 using Tapatalk 2
    Dec 2012
    Murphy, NC
    Default RESERVE
    Rather than noticing the light, I go by my trip odometer reading. At 140 miles I start looking for a gas station. Based on past experience, at 160 miles the Spyder takes 5.5 gallons. I'm averaging over 29 mpg on my ST-S.
    Invalid Emails
    Ormond Beach FL
    Default A Spyder pushes hard
    Bottom line is do you want to try pushing your Spyder to the next gas point!
    I don't!
    Mar 2012
    glenwood springs co
    washington state
    150 miles on the odometer is pushing to the limit.
    Mar 2012
    Westfield, MA
    I use the odometer and usually fill up between 130 and 150 miles on my 2012 RT. I have about 10,000 miles on it and by using the odometer I've never worried about running out of gas. I've owned too many Harley's to ever trust a fuel gauge. But that's just me. To each his own.
