Get these:
But be careful of those longer right angled ones. At high speeds they have been known to leak due to more mass wiggling about. A fellow rider had them and we couldn't figure out why he was losing tire pressure after a few laps on the track. That is, until we wiggled those valve stems.
JLohPhotos
Thanks Mike, Just ordered one. I agree if its easier than it will be done more often.
VALVE SWITCHING
Originally Posted by boborgera
When BRP contracted with a rim manufacturer back in 06 that's where the manufacturer put the hole, Simple as that! No conspiracy to make your air checking difficult.
Some times a cigar is just a cigar.
Bob I also plan to move the Valve stem on my RSS .......I'm just a " REBEL "....and I also don't choose to use genuine BRP dealer supplied air in my tires, not because I can't afford it........just because ........Mike
ABSOLUTELY DO NOT GET THOSE
Originally Posted by asp125
Get these: Those are not steel and will not work ....also the insert part is too short ....get the mtc steel 85 degree ones from KURVEYGIRL.COM NOT THE ONE PICTURED BELOW
I have 8000 + miles on my KURVEYGIRL'S AND ABSOLUTELY NO PROBLEMS......But you can do what ever you want....good Luck Mike
Thanks for the clarification. (Note I didn't research it in detail, I only suggested the style of stem)
JLohPhotos
NO HARM ...NO FOUL
GOS member (Girls On Spyders)
Daily exercise
