Exhaust gaskets?
All you high milers, when your exhaust gaskets went bad were there any codes thrown by the computer. I know on most cars with an exhaust leak before O2 sensor, codes will show up due to false mixture. Just curious to see if this happened and if a way to tell if its leaking before a full blowout. Steve
no codes
mine just started running bad. occasional backfire, cracking and popping, in the 4k rpm range. turns out just the right side clamp was loose. i put in honda gaskets anyway, to be done with it. happy ending.
![](signaturepics/sigpic7177_92.gif) it was fun while it lasted. ![biker](images/smilies/doorag.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by coz
mine just started running bad. occasional backfire, cracking and popping, in the 4k rpm range. turns out just the right side clamp was loose. i put in honda gaskets anyway, to be done with it. ![thumbup](images/smilies/thumbup.gif) happy ending.
Is there a specific Honda gasket? Perhaps a part number?
![Quote](images/misc/quote_icon.png) Originally Posted by 800steve
i have replaced mine 3 times the last time with the honda gaskets
74k no codes thrown. it just started backfiring.
![Quote](images/misc/quote_icon.png) Originally Posted by DR Buck
Honda Gasket [goldwing]# 18392-MAM-000
![Quote](images/misc/quote_icon.png) Originally Posted by juliantrost
If I'm not mistaken the Honda gasket's won't fit an RT!
![Quote](images/misc/quote_icon.png) Originally Posted by boborgera
That is correct.
MOgang Member
does anyone know the honda part number for the slip joint gasket for the RT
BUMP,!!
I know the RS gasket will not fit the RT but is there another gasket number to replace it. After market one?
![Quote](images/misc/quote_icon.png) Originally Posted by babeshorty
I could be wrong, But i don't think there is , At least if there is' It hasn't been posted.
There is none that I know of. The RT gaskets are far more robust, however, so the factory gaskets have not been a problem. If it ain't broke, don't fix it.
![Quote](images/misc/quote_icon.png) Originally Posted by NancysToy
It is my understanding that BRP actually looked into the exhaust gasket issue and made improvements based on all of us who were changing to the Honda gaskets on our GS Spyders.
RSS Exhaust Gasket
I an going to reinstall my OEM RSS muffler, but I need the Honda part number for the gasket from the y pipe to the muffler. thanks for the help
THE LARGEST GASKET
![Quote](images/misc/quote_icon.png) Originally Posted by master1309
I believe you are talking about the actual MUFFLER GASKET ? ??..If so the Honda gasket is only for the smaller exhaust pipes......Mike
You need to use the BRP gasket. There is no Honda equivalent for the muffler gasket.
