Results 1 to 25 of 42
    Springfield, MO
    Angry New swaybar....that wasn't much fun
    I have yet to find anything easy to work on on this Spyder. Everything is harder than a RS or RT. The bad news is all the 2013 share the same frame so the swaybar is pretty much going to me the same fight on all models. They have it fished in on top of the frame now and it's a real fight to get it out and to get it back in. Good thing I only had to do it once. I now have the RSS bar on my ST
    Jun 2010
    Las Vegas
    So does that mean there is one for the 2013 RT? Please say yes because they really need a beefier one.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Springfield, MO
    Ron is working on one but you may want to make sure that your shocks are up to par first. I know of one guy that had this issue.
    Jun 2010
    Las Vegas
    Quote Originally Posted by Lamonster View Post
    What do you mean? How would I know if they are up to par?
    2010 RT- 622
    Springfield, MO
    The easy way is ride another 2013 and see if it's the same. For the other guy he could tell the difference right away.
    Oct 2010
    Somewhere out there...
    Us 2013 RT owners inquiring to know...
    Default Good to know..!!
    will make sure to ask the year before mentioning how easy it is. really starting to like my 2012 don't know if the mods makes it handle like a 13 but love it as is...
    Jun 2010
    Las Vegas
    I'll have to give that a try.
    2010 RT- 622
    Henderson, NV
    Did you do the FOX Shocks too or just the Sway Bar?
    Thanks!
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    I wonder if BRP checked their demos. I rode an RTS from Vendor Village up to Battlefield and back. I thought it was less stable than my '10 with 2011 shocks on it. JMO
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    I agree the ST swaybar was a real booger to change, if you don't have a lift you will have to jack the front end up about three feet and finagle it over the frame rail, it's not a 30 minute job.
    Danbury Connecticut
    Am I mistaken ?
    I thought the upgrades to the 2013 frame/suspension meant you didn't need to modify them?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Senior MOMENTS Member
    Sep 2012
    Salem, Oregon! BUDDAH'S Country
    Default 2013 Sway Bar
    Lamonster
    Can you give everyone a drawing and dimensions (length, width, depth, diameter and hole size) of the stock 2013 Sway Bar verses the Bajaron one you installed?
    Mar 2009
    Ormond Beach, FL
    Quote Originally Posted by MrLooney View Post
    Lamonster
    I believe he installed the RSS sway bar. There isn't an aftermarket bar available yet.
    Springfield, MO
    Quote Originally Posted by mjw930 View Post
    That's correct. It's the same one BRP sells as a kit with Fox shocks.
    The hard part is not so much what you have to take off to get to it but getting the bar out and back in. Even on a lift you have to pull the Spyder all the way forward on the lift so the swaybar can swing in front of the platform. The only easy way to do this would be have an open bottom lift like Harvey has.
    Bryant, Arkansas
    Harvey (spyderpops) has all the cool tools
    Cruzr Joe
    Default 2013 RT Sway Bar Upgrade
    I am working on the 2013 RT Sway Bar now. What I really need is one more test pilot for the project. I should have the finished product ready to ship in June. As always, I could throw something out there right away and let the customer do the R&D. But haste makes waste (don't I know that!!).
    The Bar Lamont installed is the stock, BRP bar that goes on the RS-S model. There is no reason for me to make a bar for the RS, ST, ST Ltd. models since BRP already has a good upgrade available. But there is no upgrade for the RT series Spyders from BRP so I will be filling that need soon.
    Please email me at fyredad@hotmail.com if you would like to be a test pilot.
    The install isn't as easy on the 2013 as it is on the previous RT years (as Lamont said), but it isn't all that much harder. Most of our time was spent figuring out what needed to come off and how to get the sway bar out once we had it loose. If we had to do it again we'd find it easier and quicker. The big thing is getting the front of the Spyder raised up enough so the sway bar can hang almost vertical below the frame. The sway bar is about 2 ft. long.
    You start with about 8" of clearance to the frame with the Spyder sitting on the ground so jacking it up about 18" will give the ground clearance needed. Lamont's lift has a center section that runs under the frame and this was the biggest issue we faced. A floor jack will actually work better for this install than a lift (unless it has an open center area like SpyderPops).
    Jun 2010
    Las Vegas
    Email sent
    2010 RT- 622
    Henderson, NV
    Email sent
    Wow, that was fast!
    Quote Originally Posted by MMMII View Post
    Wow, that was fast!
    Good Test Pilots are usually fast....
    Oct 2010
    It was just a matter of time to get the other test pYlot!
    At the risk of getting myself in trouble, this is my 1st female test pilot! I'm looking forward to it!
    Oct 2008
    Fort Collins, CO
    Default New swaybar....that wasn't much fun
    Lamont- how's it ryde?
    Feb 2013
    New Jersey
    Lamonster,
    Did you switch out to the Fox shocks? Settings?
    Compare the ride to the stock ST-S set up.
    Jun 2012
    Roseland FL.
    I think Lamonster put Elkas on at SF.....
    Good Ryding
    Kubie
    Quote Originally Posted by Five-O View Post
    Lamonster,
