03-24-2013, 06:56 PM
#151
(Silly question here...)
A slight pulling to the right; was the road crowned a bit?
03-24-2013, 07:20 PM
#152
I'm glad you are making progress. First bad steering U-joint I have heard of. As to pulling to one side, the most common causes are failure to use the BRP tool to center the steering when replacing steering components or aligning the Spyder, and/or failing to reset the steering sensors via BUDS following alignment or parts replacement. I suspect your dealer may have committed one or both of these errors. If not, you may well have additional physical problems. Be aware that constantly pulling to one side can cause a fault, which could cause the Spyder to go into limp mode when the steering torque and steering angle sensors mismatch. Usually centering the steering and turning off the key for 15 seconds will clear the fault, but it can take multiple attempts. Be sure to have the front brakes checked if you make a long trip this way. The VSS could continually try to "steer" the Spyder for you, causing excessive pad wear on one side, pad glazing, and or rotor damage. We'll keep our fingers crossed for you. The dealer should install those adjustable bars for free for your troubles.
03-24-2013, 07:57 PM
#153
No , I was on the left side of the 2 lanes on my side of a 4 lane. It has a lean to the left. The spyder will actually pull itself over into the right lane.
03-24-2013, 08:17 PM
#154
03-24-2013, 08:56 PM
#155
Find a nearby dealer that has a good reputation and take it there. Get the 5-10% fixed.
03-24-2013, 09:15 PM
#156
they should have given you the one that worked,,,just saying.. read this whole thread.. just found it.. shaking head sideways..
03-25-2013, 07:24 AM
#157
Oh, I also wanted to mention. I called the Hamilton AL store and talked to service manager about the whole issue. He advised me that he had 2 bikes to do the ball joint campaign on but he didn't have the ball joints yet and he had never done the alignment procedure. So that also helped in the decision to leave it where it was.
03-25-2013, 08:20 AM
#158
I don't want to add fuel to the fire I really don't. However me personally with all the issues with this one I would call lemon and see if you could get another 2012 or pay the difference for a 2013. If I took this one home I would forever be thinking its not right and then anything wrong even normal wear and tear would get me worried.
i don't know what your options are, I'm sure you have exhausted them and its easy for some one like me on the other end of a keyboard to suggest such drastic demands. It sounds easy just to demand a new bike I'm sure it's not but I would be very worried about the stability of the current ride. Again not trying to get you wound up or suggest something I'm sure you've thought about yourself, just a humble opinion.
Wishing you good luck and fingers crossed it all works out in the end.
harry
03-25-2013, 10:13 AM
#159
When you first posted !
When you first posted about your problem you thought Big #1 was the best dealer. I tried to warn you! I had trouble whit them this time last year. finally got in touch with the rite person @ B R P an got mine fixed From now own I will Go to Cullum. THE SPORTS STORE They seam to now what they r doing J/S !! my 2 cents.
03-25-2013, 10:22 AM
#160
Urk...
03-25-2013, 10:55 AM
#161
Switching dealers midway through this...ordeal... might work against you.
What is it that they say about too many cooks and that broth?
I'd make sure that your dealer follows the procedures as laid out by BRP right down to the letter!
Holding their feet to the fire isn't going to make them like you any better; but once they straighten it all out; ou can make a decision about changing...
(IMHO)
When I finally go mine fixed Jeff (strongly) suggested that I would be happier with another dealer. I replied that as long as it was under warranty Big # 1 would fix it. I have since had a change of mine J/S !!
03-25-2013, 12:56 PM
#162
Originally Posted by harrypottar
...see if you could get another 2012 or pay the difference for a 2013.
It *is* a 2013.
03-25-2013, 02:18 PM
#163
harry
I have a 2013...
03-25-2013, 03:53 PM
#164
I have a 2013...
No, you have a payment for a 2013
03-25-2013, 04:25 PM
#165
03-25-2013, 04:49 PM
#166
03-25-2013, 05:23 PM
#167
Moto... sometimes the quickest shots are the best ones taken!
Rab, SORRY!
And you were so nice at first......... Now you turn against me.
03-25-2013, 05:25 PM
#168
03-25-2013, 05:48 PM
#169
Glad to hear you've made progress and are getting somewhere near 'happy' with your purchase.
Many of us that bought 2008 GS PE models, and even later ones, dealt with the horrid DPS issues BRP had early on. I had 3 or 4 DPS units installed on my Spyder. BRP finally had to do a huge recall and installed much better, heavy-duty DPS units. Our problems then were a bit different as the steering would typically just LOCK UP... as in you could barely move the bars as you were fighting what felt like a magnetic resistance.... then the resistance would let loose when you were pushing hard and WHAM... you would turn too far.
It took a good year + for BRP to get this issue properly addressed and fixed, but they took care of it as I'm sure they will your current situation.
They do listen.
03-25-2013, 06:54 PM
#170
04-21-2013, 09:13 PM
#171
04-21-2013, 09:18 PM
#172
04-21-2013, 11:19 PM
#173
Boggles the Mind
You are a stubborn bunch--next time talk to a lawyer. Non-delivery of a motor vehicle is likely grounds for rescission. Also the time for you to make the play for the demo bike was when the Can Am rep was in the parking lot and a line of new prospective purchasers were lined up to ride it.
04-22-2013, 05:05 AM
#174
Ooh that could have been both ugly (for BRP) and very fun for the the owner!
