Aero Turbo charger
Folks,
I need more speed to keep up with my BMW friends ( BMW GS and RT 1200 / 1600). I have already installed the Hindle exhaust, power commander, Kewl metal air intake and high performance plugs and spares wires. Only thing left That I can think is the Turbo mod, anyone have experience with one? what are the mechanical / electrical / performance pro's and cons of the Turbo and please no lectures on the need for more speed - let those who ride decide.
Originally Posted by blambert
Folks,
I rode BMW's for 25yr there is no way you are going to make a Spyder keep up there is 250 lbs diff more tire & wind friction those bikes are geared to run 135 all day long save your money or sell the Spyder you will blow it up trying to keep up
2010 RTS-SE, Orbital Blue
Turbo
You should take what doc says pretty much as "gospel". The man has two or three years experience with the Aerocharger amd two or three engines, clutch setups,etc. Plus, he is a certified world record speed holder in his class. The machine he used, is his every day driver.
Now, if he can just avoid "traffic schools".
Not possible buds will not let you. and Bimmer are not racing buddies.
Aero charger is the company promoting the Turbo option for Can Am Spyders
http://aerocharger.com/motorcycle_kits.php
Doc,
So you are saying that with the Aerocharger http://aerocharger.com/motorcycle_kits.phpTurbo modification I will also need to include changes in pistons, rings and lower compression
If you do what Doc says you might keep up on a the straight, but on the turns 2 wheels will leave you every time. What it will ocst you as well to do it right you probable could buy a sport bike to stay with them.
A turbo on a relativity stock Spyder won't increase your top speed,
But It will get you there quicker.........
Q: What is the stock horsepower that the Spyder engine produces?
A: Stock horsepower and torque to the wheels has been recorded as: 92HP and 63Ft Lbs of torque.
Q: What is the performance increase I can expect from my Aerocharged Spyder?
A: This turbo system will produce 140HP to the rear wheel right out of the box with room to add more boost. For more information see the dyno chart at the top of this page.
Q: How much does the turbo kit weigh?
A: The Aerocharger 53 Series turbo is approximately 10lbs, the charge tubes, intercooler, and additional Aerocharger components will add another 10-15LBS.
Q: What is this "Wide-Band" controller and gauge listed with the kit?
A: A Wide-Band oxygen sensor & digital gauge measures the Air/Fuel ratio. Monitoring Air/Fuel ratios ensure that your Spyder is running properly and safely at all times. Using this sensor and gauge eliminates the possibility of running too lean or too rich and possibly damaging the engine.
Q: Will the Aerocharger turbo kit fit on the new RTS Spyder?
A: Our kit will not bolt directly onto the Spyder RTS. However we are looking into the possibility of producing a kit specifically for the RTS. If you are in the KC metro area and have a new RTS please give us a call or stop by so we can provide the Spyder community with a solid answer. Check back for updates on the RTS fitment.
You would be surprised with my 2011 RS with Baja rons anti sway and RT front shocks at 5 setting plus keeping your eyes well through the turn at high speed, the bike tracks pretty well especially going down hill - two wheelers dont like to go fast through the twists downhill - me, no problem in fact I like because gravity is helping, what I need it torque at the apex of the turn and for straight aways - There are still more mods out there to make this thing jump
