Results 1 to 13 of 13
    Invalid Emails
    Mar 2013
    new jersey
    Default 21012 rt fuel
    I just purchased rt limited I have only 200 miles on it i had to fill up twice now my gas light came on each time I went to fill it took only little over 3 gallons also after I filled up today the bike cut off I retarted it no problems driving home any thoughts?
    Invalid Emails
    Mar 2013
    new jersey
    Default 2012 rt limited fuel
    May 2012
    Greenfield, WI
    Look at how you have the filler nozzle in the tank. If you try to put it all the way in like you would for a car, then you really wont get a full tank of gas and I can see where 3 gallons would be a fill.
    I usually put it all the way in to fill until it clicks off, then I back the nozzle out and add another 2 gallons or so till it really is FULL. Then reset the trip-ometer and go for 150 miles before the next fill.
    Bryant, Arkansas
    Did you have it running while you gassed it up? More info is needed from you.
    The more info you give the more help you will get from the GURU's on here
    Cruzr Joe
    Invalid Emails
    Mar 2013
    new jersey
    no I did not have it running when I filled it up after fill up I let it sit then pulled off I was waiting at a stop light and the spyder cut off maybe the fuel needed to flow through lines it was just weird I just bought it a week ago I filled up with super and used shell
    to the site.
    The shutting off may have just been a glitch. If the problem persists, you may need the dealer to check out what is going wrong.
    The refuel light goes on at about 120 miles most of the time. Most ,s average about 30 MPG after they are driven about 5000 miles. A lot of people base their fills on tripmeter readings rather than the gas gauge. On a really empty tank, you usually can get 5 to 5.5 gallons in. You will never get the 6.6 that the tank claims as capacity. Another caution--do not overfill your gas tank. Most people fill up to just below the ring. If you fill at the same level each time--it will only take two or three tanks and you will have the mileage on your figured out.
    There have been several gas gauge and mileage threads. Give a few of those a read if you have time.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Probably a result of the way you fill. You can't fill it like a car. Insert the nozzle just past the vent baffle (no-lead ring). Fill slowly, by hand, until gas just begins to squirt out of the vent slots. If you top it off, quit the second time the gas starts to spurt out of the slots. If you try to fill all the way to the baffle, or you fill fast or on auto, you chance forcing gas into the emissions canister, ruining it and causing gas fumes for days.
    Springfield, MO
    Your post have been merged. I would ask that you not post the exact same question twice, it makes it had to follow the answers when they are on two post. Thanks
    Mar 2012
    Florida Space Coast
    Punctuation helps, too...
    Invalid Emails
    Mar 2013
    new jersey
    My apologies for the same post twice I did not see this until now I believe my computer was freezing and I may of reloaded the page resulting in a duplicate post. Thank you for the answers and the error being pointed out. Also sory about punctuation I tend to type fast. Everyone ride safe.........
    Jan 2013
    Pasadena, Maryland 21122
    Default 2012 RT limited fuel
    I also have a 2012 RT Limited that cuts off during idle. I've made an appointment for this coming Tuesday, 4/9/13 to have a pre season check up. Ryan, the man in charge at the Hanover, Pa. dealership where I bought it will change out the fuel gauge (as it bounces all around after it moves off the full mark) and look at the cut off issue. He mentioned a throttle body issue on a previous similar problem. I can let you know the results.
    Dan
    Pasadena, Maryland
    Invalid Emails
    Apr 2012
    Canal Winchester, OH
    Quote Originally Posted by meathead1978 View Post
    The gas gauge is notoriously unreliable on Spyders. I have a 2012 RT-S SM5.
    If I hold the refueling nozzle right and upward (almost under the upright seat), that seems to maximize the amount of fuel that will be pumped into the tank.
    If I let the nozzle rest downward, I might get around 3 gallons of fuel in the tank before the automatic shut-off.
    Anyway, I have tracked mileage since my purchase new.
    My BEST fill-up was just the other day. LOL. I forgot my own rule and only put in 2.6 gallons. The fuelly.com website assumes you are FILLING the tank each time so it calculated I got 38 m.p.g. LOL.
    Typically, I get around 30 m.p.g. My mix of driving is about 50/50 i.e. city/highway driving.
    My 2012 Chevrolet Cruze gets 34 to 36 m.p.g.
    The Spyder is not a high mileage motorcycle. My last motorcycle, 1500cc Goldwing typically got 40 m.p.g.
    Default Here's what you do..!!
    Fill the tank..fill a gallon can..set the trip meter B to 00...ryde till it sputters and dies..that's how far you get on a tank of gas. Now put the gallon in and go fill up. I usually use trip meter B for mileage. You can do the same to see how far you can go from low fuel to outta fuel...
Tags for this Thread
