Originally Posted by Bob Ledford
..... You don't have to worry with lubricating the cable every time you turn around. .....
Modern motorcycles don't have cable operated clutches anymore. They are hydraulic.
The biggest complaints I have is the semiautomatic clutch is to noisesy IMO and that bugs me some of the time. The high rev shifting points are so much smoother that it is not worth complaining about. You get used to t and enjoy the ride and keep that thumb an index finger moving like the traffic around you is.
No offense Bob, but if your Spyder is still "clunking" when shifting... you may still be shifting at too low of RPM's; or simply not smoothly pulling on the paddle while holding the throttle steady (do not accelerate while shifting - just hold it steady).
I rarely ever hear a clunk-sound on mine when shifting. It is very smooth -- but not so if I do it wrong. If you are at Spyderfest, I'll show you...
First gear and reverse, however, always clunk...
Also check you oil level. Mine started to make more "noise" then usual and it turned out the oil level was low. I serviced it and shifting went back to being quiet.
Originally Posted by akspyderman
The brakes on the RT's are e-brakes. No foot brake involved here. Not sure what they did beyond 2009 on the RS's though. My 2008 and 2009 had the footbrakes, and the 2009 SE5 had the alarm as mentioned above.
Ahhh, foot brakes! I miss those days.
Originally Posted by Jerbear
The engine STOP switch. BRP even suggests it be used to stop the engine before turning the key off. It's a good habit to get into, and may, save your bacon.
What's a scenario where this will save you?
Obviously you have never had a machine where the throttle stuck or the clutch disengagement (cable or hydraulic) failed. The idea is to be able to shut off the engine without (dangerously) removing your hands from the handlebars.
Lol....is it that obvious?
