Results 1 to 25 of 34
    Inactive User
    Apr 2011
    western ky
    Default turn signal on mirrors
    I have a 2011 RT sm5 an I just bought these $(KGrHqR,!gwE+HIYW15MBP4zFi3WYw~~60_1.JPG.. I know how to remove the mirrorss from the bike but cant seem to figure out how to get inside of them to wire these up.. Any help??? Thanks
    Inactive User
    Nov 2012
    Lexington, KY
    Quote Originally Posted by kentuckyguy View Post
    I had just put some of those on myself if you need help you can help you. You can call me @859-983-6735 there is a little trick to putting the on. Fred Garrett. Lexington, KY
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Thumbs up Looks like Fed's got you covered
    Its a great mod for only $10, can't beat it. Makes you more visible from the rear & also helps to let you know if your turn signal cancel request actually worked or not. About a month ago, I dropped Teds Red Sled off at the dealer & he gave me a loaner RT-S for
    the day, and they were the first things I missed as I pulled out of the parking lot, checking my mirrors to make sure the turn signal had shut off or not.
    Getting the Mirror housings apart are a pain, there's something like 6 little tabs that you need to take a very small flat head screwdriver to pry them up, being careful to not brake them. I broke 1 on my first attempt, but the rest still hold the casing together well enough. You can use Posi-Taps to just tap the signal wires and shove it all right back into the mirror housing, simple, easy & cheap, just take your time
    Inactive User
    Dec 2012
    Central Florida,, Orlando
    Did you order them? Did you buy them in an autopart store? Pics when u put them on please...
    Inactive User
    Apr 2011
    western ky
    Quote Originally Posted by carajony View Post
    Gottem off ebay.. I will post picture when I get them on...
    Inactive User
    Mar 2009
    USA
    Try this--as Dave mentioned--be careful--but I did it with little drama. Good luck!
    http://www.spyderlovers.com/forums/s...irror-housings
    Inactive User
    Mar 2012
    Beaverton, Oregon
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Jun 2010
    Thumbs up You can pick them up in most auto parts stores, usually back in there RV/Mirror areas
    Inactive User
    Mar 2012
    Beaverton, Oregon
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    Can you also do this to a RS? and is it any more difficult?
    May 2010
    Knob Noster, MO.
    Quote Originally Posted by bmwlarry View Post
    more pics
    I drilled the little hole too, but did not take the mirror apart. Push mirror in all he way at the bottom, and drill the hole, slide wires into the hole, fish the wire out from the hole that the existing turn signal goes through, connect the arrow light to the turn signal wires, and feed back into the hole to hide in the cavity. Sorry I did not take pictures, but found the instructions on spydlerlovers.
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Quote Originally Posted by bcoulter19 View Post
    Good question
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    Quote Originally Posted by SPYD1 View Post
    Good question
    I thought so, thats why I asked it. Sorry about that, my why wife says I was born a smart a** and got worse. It has really been one of those days. I really wish someone would answer that.
    Rather than mount something in the rear field of view; I stuck mine on the inside edge of the mirror housing. I drill a hole a bit below them, and fished the wire through the housing and then hooked it into the OEMs...More Turnsignal Indicators 03.jpg
    Inactive User
    Jun 2010
    Austin, TX
    Can't say but this section is for the RTs.
    I think the RSs have a different mirror setup.
    Do a search and see.
    -Mike
    <Sent using Tapatalk>
    Inactive User
    Default Very nice..!!
    Mod should look great when your done..good luck you have all the help you need here..!!
    Active Member zbunker's Avatar
    Dec 2011
    Altamonte Spgs, FL
    Quote Originally Posted by Blue Star View Post
    Me too. I drilled the hole and installed the arrows and a strip of leds around the mirror edge. (Of course this was after I attempted to take the left mirror apart and proceeded to bust one of the tabs inside the mirror assembly ) The holes is the safest way to go for this install. Although I must say, I hate to drill holes; they are so unforgiving.
    Did you have fun getting the wiring poked down through that little hole? How long did it take you to get it hooked and pulled through? The first one; I got lucky! (twenty minutes of digging around with a piece of hooked wire). The second one was starting to try my patience after an hour of digging! Seventy-five minutes of problem-solving later...
    Inactive User
    Jun 2011
    Lynden, WA
    I drilled a small hole behind the mirror glass about center and at the opposite end of the mounting end of the assembly to the bike. I just pushed the glass in on the inside edge nearest the bike which created just enough space to use the drill bit. I then used a long zip tie to fish back and with patience came out the same hole as the existing wiring. I taped the wires in just before the connector and it works fine with no disassembly required.
    May 2010
    Knob Noster, MO.
    Quote Originally Posted by bluestratos View Post
    If memory serves me correct. I used bluestratos instructions to install my lights
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    May 2009
    Connecticut
    You don,t have to fish any wires if you follow picture below-
    2015 F3 SM6, Custom Dynamics fender lights.
    Sea Doo GTI-SE 90 Jet Ski!!
    Jun 2010
    Lightbulb Personally, I would suggest the LED strip not arrows for RS
    As stated, the RS mirrors are smaller than the RT's, so I personally wouldn't want to block any of what little you have. But you could probably put on some of the LED light strips on the edges.
    I think that somebody even has a set of lights designed for that usage... (I just don't remember who! )
    Inactive User
    Apr 2011
    western ky
    Gottem off an gottem all apart.. Just waiting on the mail man now..
