Results 1 to 16 of 16
Thread: Seat air shock
    Invalid Emails
    Jan 2012
    Louisville Ky
    Default Seat air shock
    2011 Spyder RT. Has a back rest and Rider Beads front and back. Air shock is just able to hold the seat up. Would like to put a higher LB shock on the spyder. Question is does anyone know what the original shock is as far as lb's. Or has anyone replaced with a better shock???? Thanks in advance.
    Jun 2012
    Hampton, Virginia
    Post
    Quote Originally Posted by Tin Can View Post
    Replaced mine with one a tad shorter in length from Pep Boys...works great. Just make sure the replacement is no longer than the original or your seat won't close all the way down.
    Question: How "fussy" is the Spyder about the type of ends that are on the replacement strut? Is there a particular configuration that we should look for?
    Jun 2012
    Hampton, Virginia
    Post
    I took my OEM strut with me to the auto parts store and ensured the ends matched with the replacement. If I remember correctly most of the struts in the store had the same type ends as the OEM strut.
    Thanks!
    Good idea... It's not a tough piece to carry right in with you!
    Invalid Emails
    Jan 2012
    Louisville Ky
    Thanks guys I will try the auto stores.
    Inactive User
    Jun 2011
    Richland, MO
    Default Shock lbs
    23lbs. I have a backrest and gel pad on mine and it wasn't enough to hold up when I was refilling the tank so I bought a 35lbs one and it's works great, I can even put my helmet on the seat now and it stays up. Love it.
    I bought 18.5" 35# RV Trailer Bus Door Gas Strut Spring Lift Arm Shock Prop Rod 18" 35lb from "Strut-your-stuff-here" on ebay, it cost 13$ but you can go to any RV place and get them, I tried the auto stores but the ones they carried weren't the right length or lbs. This one works great.
    It's great to know that there are other options out there!
    Inactive User
    Jun 2011
    Richland, MO
    Sure thing. O and I've seen some questions on the ends, just ask for Composite ends. They are what you will need.
    Invalid Emails
    Jan 2012
    Louisville Ky
    tamijacobs1963
    Thanks, that is exactly what I was looking for. Thanks again
    Inactive User
    Mar 2011
    Fair Oaks, CA
    Quote Originally Posted by tamijacobs1963 View Post
    I never thought about changing out the seat strut, D'oh! Is this the strut you purchased?: http://www.ebay.com/itm/18-35-Mid-Co...item5653b4ae01
    Inactive User
    Oct 2008
    Fort Collins, CO
    Nice tip. My Utopia should arrive tomorrow
    BMWLarry has a thread about this in the General Discussion area... He went with a 30lb unit from AutoZone. He said that it has no trouble holding up the seat, the Airhawks, and the backrest...
    Inactive User
    Jun 2011
    Richland, MO
    Quote Originally Posted by SpydherLuv View Post
    close this is the one i bought. Length is key.
    18.5" 35# RV Trailer Bus Door Gas Strut Spring Lift Arm Shock Prop Rod 18" 35lb...
    Inactive User
    Mar 2012
    Beaverton, Oregon
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Inactive User
    Nov 2010
    Norway, IL.
    I bought a strut that was the same brand as stock but 1/2" shorter and about 10 pounds more pressure from a place that sells truck caps. $18.00
