Welcome and congrats on the Spyder. The ride is different than a 2 wheel but I agree that once you realize this, it's a lot "funner". It took me a few instances, of going in the wrong direction, not to countersteer. The bike is great and enjoy the ride.
Teddy & I would like to say Congrats on the New Ryde & Welcome to the SpyderHood
As the Spyder 'Breaks In' your fuel miliage should increase, tho usually only by a few MPGs nothing drastic for the most part, at least that we've read about. We average about 26-28 MPGs ourselves & like many, wish it were better, but have learned after 50,000 miles or so to just Enjoy the Ryde & when we do long trips like to NY or Florida or SpyderFest or the Owners Event, we usually carry a gas can with an additional gallon, just in case. Can tell you tho, to date, we've actually rolled to a fuel pump on dead empty once, but have never had to use that spare gallon on a trip...... yet
The Spyder, as you've noticed, is a very different beast that most are familiar with, but still fun and our faces usually hurt after a spirited day of ryding the twisties, from smiling so dang much If you've not read the Do's & Do Not's Thread yet, we highly recommend it. Lots of good info for newer ryders. Good luck, have fun & most of ALL - ENJOY the RYDE!!!
http://www.spyderlovers.com/forums/s...-Spyder-owners
Reda makes a nice 1 gallon can that will fit in your saddlebag.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
How your right wrist dances with the "loud-lever" will have a lot to do with your re-fueling experiences...
You are a little on the low side, but it is likely to improve a bit when it becomes well broken in...a few thousand miles. If not, suspect a bad plug or plug wires...or an overactive right wrist. I have averaged 28 over 23,000 miles, about half or better two-up with a trailer, and a lot of it expressway. A REDA can or two in the left saddlebag, or a Rotopax container or two in the front trunk can ease your mind on those long, lonely roads.
my 2012 RT limited gets about 125 miles(about 22-23 Brisk MPG) to a tank before i have to gas up again. The REDA gas can or the rotopax gas can is a must if you are not just running around town.
Cruzr Joe
I usually fill up around 120-130 miles, but that's because I become too nervous as the fuel gauge gets closer to the E. Most tanks are 26-28 mpg although I've had them down to 24 and occasionally as high as 30. The most miles I've logged on a tank was 150+, but I figured on that trip that I was going to return to FL as a widow...having killed Ed for making me run out of gas, in his quest to purchase the cheapest gas.
You are kind of at the "low" end of the spectrum, but it could be that the needs more break in time. By 5000 miles or so, you should be getting the mileage you can depend on consistantly.
I average 30-31 mpg on both my current RT's. Both ridden solo and generally not to agressively. I usually go 150 miles between fills and it takes about five gallons at fill time. My refuel lights go on (digital gauges) right around the 150 mile mark.
Gas mileage varies, but I thinking to experiment the hydrogen fuel generating kit for add on mod. The company are claiming 30 % better mileage on their product.
It's impossible to create more energy from the hydrogen than the energy in the gas you burned to drive your alternator to power the process of driving the hydrogen and oxygen from the water. It is not a free energy thing but a scam. At each conversion there is a loss of efficiency... burning gas > engine friction > conversion of rotating force to electricity > generating hydrogen.
If you see an increase in mileage after installing the device it is because you changed your driving habits.
If it worked we would all be driving vehicles powered with water!
John
As I posted in a different thread, the reality is that the spyder isn't known for good gas mileage. Consequently, I'm getting the 1.75 gallon Rotopax gas container that I will store in my trailer.
Chris
John
That's makes me wonder too, Hydrogen powered buses in Canada, New cars hydrogen powered maybe they are just for green power.
"ST"
What rpm are you shifting at?
What rpm range are you normally in when cruising down the road?
I normally go 140 to 150 miles per fill up and get a good 30 mpg. I think it increased when I put the stripes on it.
Happy Spyderlovers
Shifting
"ST"
I'm shifting around 4-5k and my freeway speed is 65-70 in 5th gear. I tend to shift to a higher gear even around town hoping the lower rpm will equal better mileage.
Im still experimenting trying to see what would work best. I don't hot rod it i have a BMW K1200 RS for that and a HD to make noise.
Just frustrated that my other do so much better on the gas mileage.
I average 30-31 mpg on both my current RT's. Both ridden solo and generally not to agressively. I usually go 150 miles between fills and it takes about five gallons at fill time. My refuel lights go on (analog gauges) right around the 150 mile mark.
What is your average highway speeds? What's your rpm shift points?
Hydrogen fuel cell cars are a different thing but it still takes electricity to make the hydrogen. I'd have to agree they are just for the green power as they only emit water as a by product of the combustion process. If you could only get free electricity...
John
I usually shift between 4500 and 5500 (all the time now). That keeps me in lower gears around town. Very rarely do I get out of third gear in town (up to 45 MPH). The 30 mph stuff usually does not see more than second gear. Regular highway speed up to 60--I leave it in 4th gear. 65 and over is when I use fifth. The engine sounds louder, but I have found the is always ready to "go". I believe my mileage actually improved by a mile per gallon or so when not lugging the spyder--(under 4000 rpm's for me). Shifting to 5th and using it as an overdrive IMO: causes the engine to lug a little, resulting in less, rather than better mileage.
It took a little getting used to--because the shift points mentioned are not the "instinctive feel and sound" of the shifting points that most of us are used to.
Gas Mileage
We have a 2010 RT-S with 8500 miles on the odometer. We use the 93 Octane rated gasoline. Keeping the speed between 55-60 we will average between 32-34 mpgs. The best that we have had is 36 mpgs and our speed was 55 mph. When are speed is in the 70-75 mph range our mpgs drops to 25-27.
Reese
help your mileage....
Dave,
my bride says you bride should drive for a while to see if it helps.....
gas mileage..!!
We have the RS with 4500 miles on it and get 31.6 mpg's running 75/80 freeway 50/55 back roads. We use the highest octane and "seafoam" additive.
