New Spyder " Belt Stabilizer" From Baker Built Air Wings. Stops Belt Flap & Vibration
New Spyder "Belt Stabilizer™
From Baker Built Air Wings ™
• Stops Belt Flap & Vibration
• 5 Minute Installation; No Holes to Drill
• No Measuring Required; One Simple Adjustment
• Under $200.00 Introductory Offer
• Should fit most RT, RS & ST Models
(More Research needed on this)
•All Brackets 6061 Aluminum; All Hardware 18-8 Stainless
• Black Powdercoated Optional
• Patent Pending
NEW EASY INSTALLATION
1. Remove Flange Nut A in Photo 1.
2a- Take assembled stabilizer kit and install with grooved side of bracket towards tire.
b- Make sure grove in bracket fits over flange of Spyder Air Spring Bracket as is in Photo 3.
3. Reinstall Flange Nut and Tighten Securely ( See Photo 4)
4a. Pull Down Front End of Pulley Assembly Bracket and Install Belt Pulley
b. The Two nuts on belt pulley bolt needs to be adjusted so that pulley is centered over center of belt
(See photo 5)
TIGHTHEN ALL BOLTS SECURELY
Looks good!
Nice !!
Nicely done. Little competition for smoothspyder..!! Looks like an easier installation.....
Having trouble with Belt Flapping and Vibration?
Rube Goldberg
Not for me. The Smooth Spyder is a class act.
I would rather see steel used instead of aluminum; and whats to keep the roller piece thats attached to the main bar with a single bolt from slipping?
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
aluminum vs steel
We chose aluminum because it is much easier to machine grove, also the aluminum will never rust and 6061 is very corrosion resistant.
The Bolt that holds pulley is fully threaded and has a nut to hold pulley in place.. see photo
What final belt tension would you use with this?
JLohPhotos
We dont have any figures at this time, but I am sure that belt tension can be reduced to some degree. I will be doing some research on my own Spyder RT
-Bruce
